12-07-2016, 01:35 AM | #1 |
Will a 6 cyl 3 spd bellhousing fit a car 4 speed trans?
May be buying a 67 c10 with a 6 cyl 3 speed manual trans soon. Would like to drop in a sbc with a saginaw car 4 speed trans. Was wondering if anyone knows if I can use the same bellhousing? Concerned that the center hole would not be the correct size.
Any info is appreciated. Thanks
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
12-07-2016, 03:50 AM | #2 |
Re: Will a 6 cyl 3 spd bellhousing fit a car 4 speed trans?
Can't say for sure if it will fit the m21 or what ever you're using but the 3spd/6cyl bell has a smaller hole than the 4spd/350 one.
12-07-2016, 08:52 AM | #3 |
Yes. There are 2 different registration hole sizes on the bellhousing, the smaller car one that is also the same as the SM420 along with the truck 3 speeds, and the larger SM465 register.
You must use a 168 tooth flywheel with the truck bellhousing to my knowledge as a 153 tooth block mount starter won't clear the bellhousing mount built in. The car transmissions bolt into the bellhousing with all 4 bolts going through the tranny and then threading into the bellhousing. The truck trans bottom bolts screw into the transmission from inside the bellhousing at least with the iron ones I have. It could be all of mine are from 4 speed trucks but I don't think so. You should be able to use a lock washer and nut on the inside of the bolt and make it work.
12-07-2016, 10:34 AM | #4 |
The bell-housing will bolt on the the small block. Flywheel may even work, assuming you have a pre-1986 small block (2-piece main seal), but I'd replace it or have it ground. And as said above, 153T and 168T bell housings are different sizes. I kind of like the smaller one for moderate horsepower engines, because the starter location allows for more exhaust clearance, especially headers. But if this is a budget job, then run what you've got.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
12-07-2016, 10:58 AM | #5 |
Thanks guys, really appreciate the great info.
One followup question, not sure I am clear on the flywheel issue. I'm guessing the 6cyl 3spd setup comes with a 153T flywheel, and would have the corresponding bellhousing. Can I use this setup with a sbc / 4 speed assuming I have a starter that works with it?
12-07-2016, 12:23 PM | #6 | |
Another term you will hear is "clutch diameter", which is the diamter of the clutch disc. The 153T flywheels use a 10.5" clutch disc & pressure plate, while 168T uses 11". Also, the clutch disc you'll need will be either 10-spline or 26-spline, depending on the 4-speed transmission input shaft. So, therefore you have: 11" x 10-spline 11" x 26 spline 10.5" x 10-spline 10.5" x 26-spline
12-07-2016, 11:54 AM | #7 |
I believe both engines run the same size flywheel, same number of teeth, same starter.
12-07-2016, 12:34 PM | #8 |
Thank you!
12-07-2016, 08:39 PM | #9 |
168 tooth flywheels can be any and all of the above when it comes to clutches. My Jimmy has a 12" clutch stock from '72. Most 168 tooth use 11" in cars but not sure what you get in 6 cylinder trucks as I've never messed with one!
I'm fooling around with some 153 ci 4 cylinders for jeeps right now, and they use same parts as the 6 cylinders and I just found out the bellhousing thing with a mid 50's bellhousing bolted to my engine test stand. You might be able to use a starter with an unsupported nose and run the 153 tooth flywheel but I don't have a 'Denso style starter (other than the one in my Jimmy that I don't want to take out!) to test. Notice not starter... I'll swap to a car bellhousing once I retrieve it from the farm.
