Ford Rack and Pinion to LS Power Steering lines
Does anyone make a kit for stainless/braided power steering lines? I am using a 93 Thunderbird rack and a 07 LS 3 pump. I see some AN fittings on the Borgeson site but not a complete kit. Anyone know of someone making a kit????
Re: Ford Rack and Pinion to LS Power Steering lines
Ask rob at nolimit he uses the same rack on some of his kits he might know.
I bought a kit here http://www.purechoicemotorsports.com...rod/prd196.htm
It might work for you, but the 45 degree fittings hit the crossmember on my 51. So buying pieces instead of a kit would have been better. |
Hey Mallory69, How about posting up how you accomplished this? What tie rod ends, adjusting sleeves, and any brackets you built?
Goats86. You can check out some pics on my build thread http://67-72chevytrucks.com/vboard/s...errerid=155940
I set up a jig off the original lower ball joint and just built my suspension off of that reference point. Tie rod ends came from Speedway and I made the tie rod ends. I recently bought a set of billet tie rod ends from Alston chassis. |
Thanks Andrew I am probably going with the kit jweb mentioned in his post above.
http://www.nolimitengineering.com/pr...tegory=6157532 it uses a thunderbird rack maybe thats what he has.
