12-11-2016, 10:51 AM | #1 |
Stepside Tank and Compressor Mounting
Figured out where to mount tanks and a compressor on my stepside. I wanted to leave the space open between the frame rails in the back for a future Boyd's tank. I also wanted to keep everything hidden as much as possible.
I ended up using 2 tanks, 3 gallons each, one on each side. My idea is to just manage my air easily, nothing extreme or constant, for now anyway. Started working on my manual valve install under the seat and easily accessible with my left hand. This stuff is fun! |
12-12-2016, 12:57 PM | #2 |
Re: Stepside Tank and Compressor Mounting
i have dual 3 gallon tanks and dual compressors. my tanks are mounted under the stepside fenders behind the tires and my compressors are mounted on the frame.
12-18-2016, 03:37 PM | #3 |
Looks good. The step side makes it fun. I am also ruining a Boyd's tank and put my 5 gal tank between the frame behind the fuel tank
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
01-08-2017, 06:47 PM | #4 |
Completed manual valve install, no more Schrader valves.
01-12-2017, 07:11 PM | #5 |
Moderator
What is the little round thing and who makes the manual valve?
01-12-2017, 08:15 PM | #6 |
The round thing is the filtered air intake for the Viair 444C compressor. The valve is made by Air Jaxe, called the FourPlay, used to be Little Larry's.
01-15-2017, 12:47 AM | #7 |
mmmhhh interesting how do you like the set up? i am looking for a beginners set up i have prior experience with bags
01-15-2017, 01:32 AM | #8 |
Works great, easy to regulate flow with the valves.
