12-17-2016, 10:40 PM | #1 |
Gmc v3500
Looking for some good reference pics of a 91 GMC V3500. I see a few on here but they are all Chevys.
Corey 1991 V3500 |
12-18-2016, 06:35 PM | #2 |
Next!
Re: Gmc v3500
Not so common as the chevy version
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
12-18-2016, 08:53 PM | #3 |
Re: Gmc v3500
12-19-2016, 11:38 AM | #4 |
Re: Gmc v3500
I guess mine should look like the blue one above with the single headlights. Is there a way to tell which one it should have by the codes in the glove box or the vin?
Corey 1991 V3500 |
12-19-2016, 02:20 PM | #5 |
Re: Gmc v3500
RPO V22 is the deluxe grille that is the chrome one with the H4701/H4703 side-by-side halogens. Without that RPO would be the single 5x7 halogen. That is for 89-91, if your V35 is 87-88 then it would have the stacked dual 4x6 halogen headlights, RPO V22 still applies.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
12-19-2016, 02:45 PM | #6 |
Re: Gmc v3500
Awesome thanks for the help.
Corey 1991 V3500 |
12-22-2016, 04:44 PM | #7 |
Re: Gmc v3500
Well I found the grille, L and R buckets and the complete radiator support off a suburban. I hope your right about the RPO code. Where can I decipher the rest of them?
Corey 1991 V3500 |
12-22-2016, 05:47 PM | #8 |
Re: Gmc v3500
Just do a search for gm truck rpo codes
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-26-2016, 02:34 PM | #9 |
Re: Gmc v3500
If you've got a parts guy at a dealership who isn't a lazy bum he can enter your vin and print a list off the Roos with descriptions in 2-3 minutes.
Was the wiring harness available for the 89-91 front end? It isn't necessary but it makes life easier.
12-26-2016, 03:36 PM | #10 |
Re: Gmc v3500
The RPOs are common whether the truck is a Chevy or GMC:
http://www.73-87.com/chevy_ids/rpomenu2.htm A GMC pickup is a GM truck with RPO Z88 "Nameplate conversion" added. RPO X88 is what drives the Chevrolet nameplate. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-26-2016 at 03:42 PM. |
12-27-2016, 06:59 PM | #11 |
Re: Gmc v3500
Thanks for the advice, I ended up searching here paid CompNine $5 and printed out the whole list of RPOs with definitions. Meanwhile I continue to install the correct grille. The core support is mostly in but I was having trouble lining the passenger side fender up and found this gem. The grille I picked up is a little faded on the black areas, any recommendation on what paint to use?
Corey 1991 V3500 |
12-29-2016, 05:10 PM | #12 |
Re: Gmc v3500
Came out pretty good TOTM here I some lol.
Corey 1991 V3500 |
12-29-2016, 05:57 PM | #13 |
Re: Gmc v3500
Looking good. What headlights did you use? Halogens or the LMC lenses?
12-29-2016, 09:08 PM | #14 |
Re: Gmc v3500
Halogens from Napa and some new turn signal lenses from Rock Auto.
Corey 1991 V3500 |
