Old 12-18-2016, 03:22 PM   #1
Jmh68C10
Jmh68C10's Avatar
What rear setup for ls swap?
Although I have already started my project I still have a few things to sort on and plan. I am looking for advice on rear end setups. I am swapping in a 6.2l/4l75e drivetrain. I want to use the stock 12 bolt. What kind of gear locker setups are ls swapped truck running? I am going for good driveability
Jmh68C10 is offline   Reply With Quote
Old 12-18-2016, 03:56 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What rear setup for ls swap?
I'm running the stock 4:10 gears in my 6.0 4l80e setup!
I'm getting about 16-18 MPG on the road.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-18-2016, 04:30 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I am using a 3.73 Posi in the '67 Panel Truck with the LS1/4l60e combo. Runs really good and I got almost 24 mpg on the secondary roads when we went to Kansas City last September. I was running 60-65 most of the way.
LockDoc
Leon
Old 12-18-2016, 05:11 PM   #4
Willie Makeit
Willie Makeit's Avatar
no idea on the mileage, but running a 3.73 with an Eaton posi behind a 5.3 / LSA supercharger and a 4L80e
Willie Makeit is offline   Reply With Quote
