Old 12-18-2016, 05:02 PM   #1
profe56
350 engine
Hi folks:
Yesterday I bougth a supposed 350 engine,I hope it is 350, I found this engine was madr in Mexico.
profe56 is offline   Reply With Quote
Old 12-18-2016, 05:05 PM   #2
profe56
Originally Posted by profe56 View Post
Hi folks:
I need to know if it really is 350, I also noticed there are no numbers at front of the passengers side head
Old 12-18-2016, 05:29 PM   #3
72bowtiestepper
Re: 350 engine
Prob. a crate engine....the 260 hp & 290 hp 350 engines & possibly others are Mexican blocks. No worries...they are good engines....many have put lots of miles on them with good results.
72bowtiestepper is offline   Reply With Quote
Old 12-18-2016, 05:38 PM   #4
YJ_Aaron
Re: 350 engine
Most likely go crate engine. All of those blocks are made in mexico. Look at 3 digit block casting in front of starter. Guessing it will be 880 casting.
YJ_Aaron is offline   Reply With Quote
Old 12-18-2016, 05:52 PM   #5
Alex V.
Alex V.'s Avatar
Re: 350 engine
If it is a crate engine, have they always been 4-bolt blocks or was that only a more recent thing? Could very well have 4 bolt main caps.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 12-18-2016, 06:00 PM   #6
YJ_Aaron
Re: 350 engine
Not all are 4 bolt blocks. Depends what part number and where it's built. I believe all the performance part builds are 4 bolt, the others are mixed.
Pull valve cover and look at that casting should tell you the story.
Also there are crate short blocks from GM. We build a couple of those like 383HT.
Old 12-19-2016, 12:19 AM   #7
profe56
Old 12-19-2016, 12:26 AM   #8
profe56
Thank you guys for all of your answers, if everything is ok in the future I'll do a lot of questions because I want to built an strong engine.
Old 12-19-2016, 12:25 AM   #9
randy500
Re: 350 engine
3970010 are usually 4 inch bore blocks, maybe always so it is likely a 350. That's a weird motor though, cast iron waterneck, 2 bbl. It is older syle though with the large VIN pad and the oil galley plug above the timing cover. Another weird thing is the heads don't appear to have a full set of accessory holes.
randy500 is offline   Reply With Quote
Old 12-19-2016, 09:33 PM   #10
garyd1961
Re: 350 engine
Is that a 350 damper/balancer ? It looks a little thin.
garyd1961 is offline   Reply With Quote
Old 12-20-2016, 10:48 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: 350 engine
Re. why it looks different. Seems like the previous owner bought a short block and used the parts of his older engine.
The intake almost looks like the one I took off my old '69 Chevy truck.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-20-2016, 04:13 PM   #12
GRX
GRX's Avatar
Re: 350 engine
Yeah. #3970010 + mexico = 350 block. Date code should be on the bell housing flange as well. Though one can never be sure with Mexican castings.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 12-21-2016, 04:11 PM   #13
profe56
Re: 350 engine
Thanks folks for all of your opinions. I will now if is really 350 as soon as I open it, I wiil keep this thread, I hope the engine is in condition to be rebuilt it, if is, I will need your help with your suggestions on how to make it strong.
Thank you again
Old 12-22-2016, 04:05 AM   #14
Kenfuzed
Kenfuzed's Avatar
Re: 350 engine
Thank you again
Suggestion for making it strong... push it to the curb and buy a new crate engine
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-22-2016, 06:39 AM   #15
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 350 engine
This is very good advice because you'll be way over $1500 getting that motor up to snuff. I bought one of these like many others here and for $1500 delivered it's hard deal to beat. Three years ago these motors were going for $1200 delivered, mine still on the stand waiting for my previous $2500 rebuilt motor to wear out. http://www.jegs.com/i/Chevrolet-Perf...67353/10002/-1
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-22-2016, 08:51 AM   #16
homemade87
Re: 350 engine
I would not push it to the side if you are looking for performance . Being you have the block and it checks out I would consider a 383 stroke kit . For what you want to do you could get a 383 stroke kit for around 800.00 . Have the machine work done and assembled for around 300.00 to 400.00 . Less if you decide to assemble yourself . This would give you options for a much better head if wanted (cam also ) . If you will be satisfied with 200hp by all means get the crate motor . If you buy the crate motor and decide to mod for more power later you will spend a good bit more than the 1500.00 and not get close to the 383 potential . So I guess it boils down to where you want to go when you say performance . Performance has a pretty broad meaning .
homemade87 is offline   Reply With Quote
Old 12-26-2016, 02:54 PM   #17
GRX
GRX's Avatar
Re: 350 engine
Well, no way to be certain it is a 4-bolt main without pulling the to pan look. And I never was a big fan of Target Master engines. Most every one I received had factory rejected parts. Got a whole run of 350s from fleet service with misaligned cam journals repaired with offset spacers. Mexican castings were the worst.
