Old 12-19-2016, 09:10 PM   #1
dec010974
dec010974's Avatar
A bunch of hot air
Hello to all. I need help with my LSx o2 sensors. As I look at the scan gauge on my LSx swap, I noticed that my O2 sensors aren't responding to the PCM. My exhaust Is open due to the fact that I was rejected by the muffler shop due to leaking gas from the fuel sending unit. The loose AN fittings was tightened, fixed. Is there any reason why the 02 sensors are dead? I would hate to buy new sensors and not Resolve the issue. Thanks in advance, Clark. I did the harness myself.
dec010974 is offline   Reply With Quote
Old 12-19-2016, 11:16 PM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: A bunch of hot air
How close to the open end of the exhaust? I wouldn't worry much till the pipes are on.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 12-20-2016, 02:00 AM   #3
izzy_Britton
izzy_Britton's Avatar
are you sure that you didnt program the o2 sensors out of the computer?
I ask because when i had my computer re-programmed i had the aft o2 sensors removed as emissions compliance is not necessary.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 12-20-2016, 10:20 AM   #4
dec010974
dec010974's Avatar
Big port jimmy 6, the 02 sensors are very close to the end of the open exhaust. Also the tuner stated that the 02 sensors aren't responding. Izzy Briton, I'm referencing the front o2 sensors. The rear sensor will be removed from the tune.
Old 12-20-2016, 11:02 AM   #5
Hart_Rod
Hart_Rod's Avatar
Why do you think they are dead?
Hart_Rod is offline   Reply With Quote
Old 12-20-2016, 06:30 PM   #6
dec010974
dec010974's Avatar
Hart_rod, the scan tool has a listing/display that shows the activity of the o2 sensors of live data. While the engine is running, The data or activity of the o2 sensors Will be bouncing around, calibrating itself as the engine runs. I was told that the o2 sensors activity, ranges from 5 thru 450, which means rich or lean as the pcm interpret this info. I may have left out a thing or two but the geeks will know what I'm talking about. You gotta love the smart guys. They built this country. In my case, the o2 sensors show this symbol (-). This symbol - is not a number from 5 thru 450. That's why I say the o2 sensors aren't responding. I'll check in the morning. The exhaust was installed today.
Old 12-20-2016, 07:52 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Are they stock 02 sensors? The ( - ) means its not getting ANY signal from the 02. Any chance you've got em wired wrong?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-20-2016, 08:40 PM   #8
dec010974
dec010974's Avatar
Brew city, I am offended. Me, wire the o2 sensor wrong? Brew, I never. Lol, I used GM schematics while fabbing up the wire harness. I did change from the square sensors to the flat o2 sensors. The wiring is as follows d-ignition, c-harness ground, b-#66 or#69 pcm, a-#26 or #29 pcm. What's next brew?
Old 12-20-2016, 10:32 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Check the fuse panel. They can pop the Engine Sensor Fuse, 10a
Old 12-20-2016, 11:53 PM   #10
clinebarger
It should display a Voltage Value, Unplugging the O2's should yield close to 450 MV (Open Circuit).
clinebarger is offline   Reply With Quote
Old 12-21-2016, 08:42 AM   #11
dec010974
dec010974's Avatar
Brew, it can't be that easy as just exchanging a fuse. Hard is the story of my life. Cline I'll check the millivolts. I will also check the continuety of each wire and unplug/plug each 02 sensor. Thanks Fam. I'll post the results.
Old 12-21-2016, 08:49 AM   #12
Hart_Rod
Hart_Rod's Avatar
I'm assuming you are getting a check engine light or no?
Old 12-21-2016, 02:06 PM   #13
dec010974
dec010974's Avatar
Alright boys and girls. I unplugged the o2 sensors, then plugged them back up prior to start up. I cranked the Motor and plugged up scan gauge. I saw 3 codes that deal mass air flow. I'm running a speed density tune. The o2 sensors are responding. They read around around .445 as clone stated. Clinebarger wins the prize. Thanks my c10 family. Happy holidays. The tune will come and adjust my tune now that The exhaust is buttoned up.
Old 12-21-2016, 02:24 PM   #14
Hart_Rod
Hart_Rod's Avatar
So there was nothing wrong
Old 12-21-2016, 02:58 PM   #15
davepl
davepl's Avatar
You might want to try in the LS section:
http://67-72chevytrucks.com/vboard/f...play.php?f=206
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-21-2016, 08:32 PM   #16
dec010974
dec010974's Avatar
This is the LSx section. @ hart Rod, I guess I'm lucky. There was nothing to fix. The sun does shine on a dogs azz, sometimes.
Thanks again Fam.
