12-21-2016, 09:35 PM | #1 |
Four Seasons info needed
New member here.
I have a 1969 C10 with factory A/C and I need drawings for the interior vacuum routing and also the actuator cable routing Thank you! |
12-21-2016, 09:46 PM | #2 |
Re: Four Seasons info needed
Welcome..I broke down and bought a factory assembly manual.....there's no rhyme or reason to the way it's compiled but everything to do with the 67-72 is in there somewhere.
http://www.ebay.com/itm/1967-1972-Ch...ngjDJA&vxp=mtr
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
12-21-2016, 09:52 PM | #3 | |
12-21-2016, 09:57 PM | #4 |
Thank you
I should have picked one of those up when We started my sons project. We had marked everything upon disassembly but something is not correct. If anyone has the means to post the needed info/pages it would be greatly appreciated Posted via Mobile Device |
12-21-2016, 10:16 PM | #5 |
Old member
Here you go!
The only difference in the two prong and 3 prong is the two has a tee in-line for the 3rd hose. For the cables. Top slider is deforst cable which hooks in the front in the floor on the heater vent next to the floor. Middle cable is the AC compressor cable which connects behind the vents inside the cab. Bottom cable goes out to the engine side to the flapper to close off the outside air. I just realized I have the top and bottom swapped! I got some work to do!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-22-2016, 09:38 AM | #6 |
Thanks very much guys
Seems like I have many more vacuum lines inside than should be I will take a look today Thanks again!! Posted via Mobile Device |
