Raised wheel tubs
Hey guys I'm new to the forum,thanks for the add. I was wondering if anyone had any links or info on raising the stock wheel tubs in the rear. I'm building an 87 short bed, bagged with extensive rear set up, ridetech up front and a 5.3 setup. Thanks
Re: Raised wheel tubs
Are you raising the bed floor as well?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
http://www.sloshtubz.net/ hills website is acting up for me but http://67-72chevytrucks.com/vboard/s...d.php?t=465046
No I'm not raising the bed floor, just trying to reuse the factory tubs.
#5 | |
Happy to be here
![]() Join Date: Mar 2000
Regardless, unless you have the ability to weld a sectioned tub your best bet is look at Slosh Tubz
#6 | |
Hills does its for the 67-72 trucks but could be made to work.Or if you don't care if it looks factory ish http://www.avsontheweb.com/notch-covers/
Even so. I agree with Ken. If he's not raising the floor what is he gonna gain from it? I'm not being a smart ass. I'm sure I'm missing something.
Sorry for the confusion guys, I'm not raising the floor but it is cutout for the notch to come threw the floor, I already have that cover built. I'm just looking ideas for the wheel tubs. Thanks for the responses guys.
Will the tire hit the top of the rear tubs when you're aired out?
Yes, I'll try and get a pic uploaded. I'm going to try and just add 4 inches to the factory tubs to make them taller.
Raise the attachment points of the tubs on the inner bedside however much higher you need. Drill new holes & use nutserts/rivetnuts to get it done. Bolt the tubs in. Then make filler pieces to fill the gap between the vertical portion of the tub flange @ the new higher location to the original floor.
