Old 01-03-2017, 08:11 PM   #1
kbrown
Headlight problems
I have a 72 burb,I have replaced my dimmer switch and I have high beams at the light but no low beams, I have voltage coming from the low beam side of my dimmer switch but nothing at the light, has anyone else run across this issue .Thanks Kevin
kbrown is offline   Reply With Quote
Old 01-04-2017, 01:09 AM   #2
HO455
HO455's Avatar
Re: Headlight problems
Check for voltage at the headlight. It will be either the light green or the tan wire. (Tan I think for low beams) If no voltage then check the same colors at the firewall connector. You may have to unbolt the connector to access the pins. If you have voltage at the headlight test the bulbs with an ohm meter.
Good luck.
RIP Bob Parks.
