![]() Join Date: Mar 2014
I'm out of whack somewhere... but where?
New body mounts (energy suspension poly's) and I kept the original shims in place with new washers, but the cab seems to be high on the driver side, and the control arms seem to sit at different angles.... any way to adjust?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
Re: I'm out of whack somewhere... but where?
First photo is passenger side arm and second is driver
These arms seem to be at different angles...
The Older Generation
Sounds like one of your front coil springs may be weak and sagging.... LockDoc
Which is strange cause they're brand new, with barley 100 miles on them.
#6 | |
LockDoc
Looks like you need to do more research and measuring to see if and what is bent or installed incorrectly.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I did notice however that my springs (when truck is jacked and no weight on suspension) my drivers spring I can move with my hand and passenger is movable but much tougher to move/wiggle. They're 3 inch CPP drop springs.
Make sure the springs are seated properly into the notch in the lower control arm?
On a 68 1/2 ton, leaving one out of the notch caused that side to ride higher by about an inch. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Tags |
alignment, body mounts, cab |
