Battery's
Hi
I was thinking of removing the battery from the engine bay Then mount 2 6 volt battery's behind the seat. Has anyone done this? I would put each battery in a battery box and Secure it to the floor. I have seen where people mout the battery under the Bed or in the bed but I am not crazzy about eather location for different reasons. If it is behind the seat it is out of site and protected form the engine heat. What do you think? Any down side?
![]() Join Date: Feb 2016
Re: Battery's
The reason for putting in behind the rear axle is to improve the weight distribution. The con's are much longer larger cables to the starter and alternator. If your not racing the truck there really isn't a good reason to move the battery. In this day and age batteries are engineered to last a long time under the hood. I would highly advise against moving it inside the cab. If you move it inside you MUST have the battery bolted down inside an airtight box that is vented to the outside of cab. Batteries vent off dangerous fumes. Sorry to come on so strong but there is a real danger.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Jan 2001
Re: Battery's
The cab is an unvented space, and lead-acid batteries produce hydrogen sulfide gas. I don't think it's advisable.
#4 | |
Re: Battery's
My Z06 has the battery in the passenger compartment (trunk/hatch area) but it's vented with a tube.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#5 | |
Re: Battery's
![]() Join Date: Oct 2009
Re: Battery's
They aren't put in the cab of anything for a reason - and truckster's is a good one. But also, in the event of a crash, the last thing you want is a battery (or two) getting shattered about a foot behind your behind.
Re: Battery's
exactly....thats why its much safer to have the gas tank there....
1970 short step c10 leaf spring 454 |
#8 | |
Re: Battery's
If you designed a battery box that was sealed and vented to the exterior it might be a worthwhile project, but what gain would there be from all that work? Maybe if you're building your truck for autocross, but then why not just mount the battery in the bed? Hydrogen is a normal product of charging a lead-acid battery, and becomes explosive at about a 4% concentration. That's not the big concern - any overcharging of the battery induces sulfur to bond to the hydrogen, producing hydrogen sulfide, which is an extremely poisonous gas. And if you're running a mechanical voltage regulator you're likely to get some overcharging periodically. Is it a huge risk? I don't know, but I don't see any benefit from running the risk. Last edited by truckster; 01-05-2017 at 02:32 PM. |
Re: Battery's
I'd like to know the reasoning unless its so you can sit with the vehicle off and listen to the radio longer...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
