Old 01-06-2017, 09:07 PM   #1
miller6t9
miller6t9's Avatar
a question to those with big diameter torq thrust II...
just wondering if those with the large diameter TT IIs (17, 18, 20) have custom offset or are they off the shelf wheels?...been doing a lot of looking and not many put the offset and backspacing of their wheels out there.
miller6t9 is offline   Reply With Quote
Old 01-06-2017, 09:17 PM   #2
Mike C
Mike C's Avatar
Re: a question to those with big diameter torq thrust II...
Most are off the shelf. A zero offset wheel works best on both ends of these trucks usually. My wheels are 5 lug legend 5 spoke and not Torque Thrusts, but 17x8 front with 4.5" backspace and 17x9 rear with 5" backspace.
Backspace measured from the outside of the wheel while wheel width measured between the beads. So an 8" wide rim is approximately 9" wide outside to outside, thus a 4.5" backspace has the mounting surface almost centered resulting in a zero offset. Meaning the mounting surface flange neither pushed to the front or rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-07-2017, 03:40 PM   #3
68racer
Yeah baby!
68racer's Avatar
I had custom 18x8.5's made for the rear as off the shelf had too much backspace.
11.37 @116
68racer is offline   Reply With Quote
