Old 01-09-2017, 06:15 AM   #1
chevylemon
Stuck shackle bolt help!
68 c30 how do I remove the rear, greasable, shackle bolts?
I've let it soak in pb blaster, used a torch, and a bfh. Won't budge.
chevylemon is offline   Reply With Quote
Old 01-09-2017, 09:51 AM   #2
Re: Stuck shackle bolt help!
Thin cutting wheel on a mini-grinder between hanger and shackle. It's tight and I have ended up cutting into the hanger a bit, then welded up. I have tried a sawzall with the best blades out there and let me tell you, don't even bother. Those are some hardass bolts!
Old 01-10-2017, 11:29 PM   #3
El Dorado Jim
I have done it this way also
El Dorado Jim is offline   Reply With Quote
Old 01-09-2017, 10:12 AM   #4
hamjet
hamjet's Avatar
Also, if you have a cutting torch setup you can heat the heck out of it and try turning the end of the shackle bolt thats sticking out with a pipe wrench..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-09-2017, 12:50 PM   #5
Coley
Coley's Avatar
...built tough to last, 45 years+ on....lol.
Not necessarily good news today tho' unfortunately
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 01-10-2017, 10:49 PM   #6
chevylemon
Originally to take it out was that one Allen pin and bump it out? Might just have to cut it out and use grade 10 bolts
Old 01-10-2017, 11:40 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Can you provide a reliable link to the description of Grade 10 bolts?
~Steven
Simi Valley, CA
Old 01-12-2017, 09:44 AM   #8
chevylemon
Metric grade 10.9 or your sae grade 8 are equivalent http://www.tessco.com/yts/customerse...bolt_grade.pdf
Old 01-12-2017, 05:14 PM   #9
El Dorado Jim
I have only heard of grade 2,5 and 8 bolts unless you are talking aircraft grade or something like that, grade 8 is all you need.....do you know how to tell the different grades?
