Door corner patch
I have seen them online, can't find now for some reason. The little lower inner corners where the seal goes. Where did I see them?
56' 3100 shortbed |
Re: Door corner patch
Have you looked on LMC Truck?
A pic and/or a yearseries would help. Inner, outer, front or rear of door would also help.
Yep checked LMC, Saw them somewhere 56' 3100
56' 3100 shortbed |
Here's the passenger side
https://www.c2cfabrication.com/produ...oor-skin-patch
1959 Apache 3100 Fleetside short bed 235 l6 |
I would suggest a little sandblast treatment of the back side of the door skin while you have the part cut off and before welding in the new part. are you doing the whole lower, front to rear, or just a patch made from the new panel?
That looks easy enough to make from scratch.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
check these out
https://www.c2cfabrication.com/produ...FdWNfgodH8oLKg
