Old 01-14-2017, 07:31 PM   #1
WB72
Before and After
WB72's Avatar
Window Regulator requiring attention.
Is there any point to removing and rebuilding the window regulators out of a 72? Repop ones are like $30 per side. Are they good quality?
Mine are just plain hard to roll both up and down. Before I disassemble, I would like to know if they are worth saving and repair, or order new ones before I disassemble so they can be reinstalled that day.
If I rebuild, what should I expect to do for smooth operation? What parts should I have on hand?
I'm sure they have not been serviced in 45 years.
Thanks in advance.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-14-2017, 10:50 PM   #2
berch 69GMC
berch 69GMC's Avatar
Re: Window Regulator requiring attention.
Had the same dilemma recently. I ordered a good mark from rock auto, installed it and so far so good. I plan to blast the original and replace wheels. Use it as a backup if the repop quits.
berch 69GMC is offline   Reply With Quote
Old 01-15-2017, 02:02 AM   #3
LongBox
Following this, as my passenger side is not operating properly.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 01-15-2017, 02:29 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I asked about repro. quality sometime back, and the results were a mixed uncertain bag. If yours operate correctly then I'd freshen them up. Add new wheels if necessary as stated. I hear bad wheels is common, but on mine they were great. The LH side is fairly worn out though. Go figure the spring was rusted badly. One of only two signs of rust on this build. The other was the LH door sill.
Your OP says "rebuild".. That sounds like new gears, spring and ?.........Does anyone do this?
NOS are expensive and few & far between. I bought one, and it took about one year to find it too. From what I gather there are few options outside Repro., but a new U]OER[/U] regulator is probably inferior a good OEM. Some great vendors on this website for repro. Maybe even an OEM reg..
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-15-2017, 02:49 AM   #5
truckster
truckster's Avatar
It's amazing what a little white lithium grease can do.
Also look at your window felt - the track the glass runs up and down in. If they're worn out the can cause the glass to bind.
truckster is offline   Reply With Quote
Old 01-15-2017, 05:36 AM   #6
WB72
Before and After
WB72's Avatar
I will likely be installing new felt and weatherstripping at this point.
Is it as easy as you say, grease it up and its good to go, pending damaged parts?
66,000 miles.
Alberta, CANADA
Old 01-15-2017, 05:30 AM   #7
WB72
Before and After
WB72's Avatar
Thanks for the great info
I do not have mine out of the doors yet, so I don't know the shape they are in. I am expecting rusty mechanisms and felt would be hard. the truck is in pretty bad shape at this point.
If the wheels need to be replaced, can OEM ones be found, or are they repops?
If you have rebuilt them in the past, walk me through it.
I don't need OEM, I just want them to work.
66,000 miles.
Alberta, CANADA
Old 01-15-2017, 08:39 AM   #8
Bigdav160
Bigdav160's Avatar
I haven't had any problems with the repops.
Make sure to lube the window runs with spray silicone.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-15-2017, 01:22 PM   #9
chadzilla500
My LMC repops are as smooth as silk. No slop.
I put in new felts and did one piece windows as well.
chadzilla500 is offline   Reply With Quote
Old 01-15-2017, 04:24 PM   #10
cdowns
cdowns's Avatar
if you spray some wd40 on them to clean up the 45years of built up crap on them then spray a little bit of lubriplate on them they'll b good to go for another 20years // takes about 5minutes and the cost is next bto nuttin
Old 01-15-2017, 05:56 PM   #11
71CHEVYSHORTBED402
I cleaned mine with WD40 and brushes, degreased, and then lubed them up with lithium. The RH was real happy, but not the left. The spring pops. Couldn't tell you if it's the spring itself or something causing it, but the spring was pretty rusty.
Tony
