Old 01-18-2017, 11:43 AM   #1
demian5
demian5's Avatar
Wiper Cowl Removal
Can I remove the wiper cowl panel without removing the hood or fenders? I want to clean and lube my wiper linkage.
Thanks in advance for any assistance.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-18-2017, 11:52 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wiper Cowl Removal
Yes,
pop the hood first. There should be about 4 phillip head screws under the rubber gasket for the hood holding it in place.
Then 4 more smaller phillip heads at the grille area of the cowl take those out.
Take both wipers off and washer nozzles hose loose.
Then open each door there is a 1/2" head bolt staring at you take them out they are Hortzonal.
There are also 2 that are straight in front of those 2 toward the front of the cowl which are vertical.
That's it you can lift it off but be carefull you will want some one to help you.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-18-2017, 12:23 PM   #3
demian5
demian5's Avatar
Originally Posted by Andy4639 View Post
Yes
Thank you so much!
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-18-2017, 12:25 PM   #4
LongBox
Highly recommend getting a windshield wiper arm removal tool. Under 10 bucks at the local auto parts store, and makes the job real easy. I think mine was made by Lisle, and was a round 7.99.
While you can do quite a bit of cleaning while you are in the cowl area, you cannot really get at all the areas that tend to rust, as there is more sheet metal to remove. Easy to lube the wipers as you planned.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 01-18-2017, 12:50 PM   #5
DarkFlounder
Aren't those called crow bars and cussing?
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline   Reply With Quote
Old 01-18-2017, 03:07 PM   #6
tdangle
tdangle's Avatar
X2 on the above
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 01-18-2017, 04:05 PM   #7
Andy4639
Old member
Andy4639's Avatar
NAPA tool makes it easy to take the wipers off.
Old 01-18-2017, 02:59 PM   #8
el_fantasma
el_fantasma's Avatar
Subscribed
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
