Old 01-22-2017, 05:54 PM   #1
Buggalugs35
Buggalugs35's Avatar
Switch on the side of the 3 speed Muncie
I have searched and searched and cannot for the life of me find what the switch on the side of the Muncie 3 speed is. I thought it was the reverse light switch until I realized it is on the 2-3 shift shaft. I put a new switch in to wire it up and my reverse lights stay on unless I put the truck in 3rd gear.
The little black cable that goes to the switch runs along the bellhousing toward the passenger side of the truck
My granddad owned the truck before and moved the column shift to the floor and just painted the reverse lights red and hooked them to the brakes. I have been rewiring the truck and wanted to make them right.
It's a 71 350, any help would be much appreciated. My Chilton shows the switch but not what it goes too.
http://i50.photobucket.com/albums/f3...pste9owl4q.jpg
http://i50.photobucket.com/albums/f3...psn0ozqpdh.jpg
http://i50.photobucket.com/albums/f3...psdfphmn3q.jpg
Buggalugs35 is offline   Reply With Quote
Old 01-22-2017, 06:10 PM   #2
Boog
laying low
Boog's Avatar
Re: Switch on the side of the 3 speed Muncie
Considering your truck is a 71 it could be that switch is part of the ESC circuit. That's ignition spark control that limits advance until the vehicle is in 3rd gear.
The backup light switch should be on the steering column inside.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-22-2017, 06:17 PM   #3
Buggalugs35
Thanks that makes more sense.
If I switched to HEI with vacuum advance do i need that switch anymore?
Old 01-22-2017, 06:18 PM   #4
PatrickGMC70
PatrickGMC70's Avatar
On my 70, it's TCS - transmission controlled spark. Someone who knows more than me can explain it better than I could. I think it's an emissions gizmo.
PatrickGMC70 is offline   Reply With Quote
Old 01-22-2017, 06:22 PM   #5
Buggalugs35
Thanks, I guess Ill just cap it off, i dont have any emissions controlling stuff hooked up.
Old 01-22-2017, 06:54 PM   #6
geezer#99
geezer#99's Avatar
It's a ground switch. Just leave it unplugged.
It was as said a tcs.
A solenoid that controlled when your vac pot got vacuum. THe solenoid had 12v to it with the ground switch on your tranny activated when in high gear.
Used on trucks mainly for ones that would haul heavy loads and needed more initial timing and couldn't use any extra timing from the vac advance until in high gear and cruising. Also used on some high perf cars that needed more timing on the bottom end for their increased compression.
You can run one with your hei as it's independant of your distributor.
And fwiw it wasn't an emissions device.
Old 01-22-2017, 08:52 PM   #7
scooterpimp
scooterpimp's Avatar
Wow my 3 speed saginaw has the same deal. I was wondering why i couldnt get continuity in reverse. Well thats one more mystery wire i dont need to connect , now gotta figure something for reverse lights on floor shifter....
scooterpimp is offline   Reply With Quote
Old 01-23-2017, 01:50 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Switch on the side of the 3 speed Muncie
Not knowing what floor shifter you have but I used a mini micro switch. Easy to hookup and you can buy different length arms on them.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-23-2017, 01:53 PM   #9
Buggalugs35
Is anyone familiar with the hurst indy shifter and/or a reverse light switch to use for it? I really want to be able to have the lights come on without an extra switch.
Old 01-23-2017, 01:56 PM   #10
Buggalugs35
On those micro switches what does the 3rd post go to?
Old 01-23-2017, 06:12 PM   #11
scooterpimp
Micro switch is the trick , i have access to alot of them , just gotta mount it to my hurst3 speed setup. Cool.
Old 01-23-2017, 01:57 PM   #12
Bigdav160
Bigdav160's Avatar
Sure it was. It altered the advance curve the the distributor to try and control HC/CO emissions. This system was eliminated when catalytic converters were implemented.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-23-2017, 02:17 PM   #13
geezer#99
geezer#99's Avatar
If so then why wasn't it standard equipment on all the motors?
And what about the trucks that still had them after the start of convertors.
