Blazer total height with 4" lift and 33" tires?
I am currently working on a 70 4wd blazer project and doing a frame off restoration. Bought the vehicle from a shop, while they are starting body work, i took the chassis to mock up with ls/4l60e and then get everything powder coated.
My dilemma is i am not sure what lift it currently has, but would like to go with a 4" suspension lift with 33" tires, but am limited to my 7ft garage. I have done some searching here and found some evidence that it will barely clear as well as calculations based off spec'd stock height and tires. I know there is probably variation between suspension brands, but I am asking for help if any members have this setup, could do a quick height measurement to the top of the hard top!? I would appreciate it greatly so i can feel confident ordering the correct lift. Thanks, Aaron |
Re: Blazer total height with 4" lift and 33" tires?
Mine measures 6'8". It is 4" rough county lift suspension lift and 33" tires
I think the ride could be better. I'm by no means a guru on suspensions but the price was right, and I think you would have to spend a lot more to increase the ride quality to a point that it was noticeably better.
Anyone else lend a hand? Could use a couple more measurements on other to increase my confidence level!!
I just measured mine. It's a 70 also with 12.5X33", Softopper and no lift. It's 6 foot 4" (74")
![]() Join Date: May 2006
My opening in the workshop is 76 1/2" 4" lift with 31" tires. truck goes out and in
[url=https://flic.kr/p/MrhdhV] ![]()
![]() Join Date: Apr 2012
Dan was using the "metric" inch up here in Canada.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Yep, thanks everyone, feel pretty confident, going to pull the trigger on the 4" leaf springs...if too tall i guess i can load it up with some sand bags, lol
now just need to decide if i want to save a few bucks and go rough country or shell out more for a softer ride! |
Carpe manana
![]() ![]() Join Date: Dec 2010
I've got a 4" lift and 33's on my green blazer and it clears a 7' door and measures ~79" tall. On day I'll downsize the lift - too tall for my liking and I'm worried my wife will tear off the gb door when she scrambles inside.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
My '70 is also at 79". But,.. I have 35's, 4" front rancho and 3" rear blocks. So feel more confident?, Or more confused?
