01-22-2017, 10:13 PM | #1 |
Quick door alignment question
I did already search the forum but didn't get the info I'm looking for.
1970 c10 The passenger door sticks out past the cap on the lower latch side. The rest of the door is pretty close. I thought I would loosen the top hinge bolts on the door and push that out a touch but it's maxed out on adjustment. 1. Is this the adjustment I should do? 2. Since the hinge is already at max adjustment should I shim out the top hinge at the fender to achieve the same movement? Thanks. Mark. |
01-22-2017, 10:37 PM | #2 |
Re: Quick door alignment question
Would like to help but,
Seriously, I'm not sure as to where your misalignment is, so some photos would make all the difference.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-22-2017, 10:45 PM | #3 |
The Older Generation
Me too.... I'm not sure what you mean by "out past the cap on the lower latch side". Did you mean out past the cab? LockDoc
01-22-2017, 10:47 PM | #4 |
Misalignment is the door sticks out past the cab corner. Rest of the door is pretty good. I'll post a photo when I get the repair panel welded on.
01-22-2017, 10:52 PM | #5 | |
Is the window frame hitting the cab at the top front by the drip rail? LockDoc
01-22-2017, 11:05 PM | #6 |
01-22-2017, 11:11 PM | #7 |
Not the drip rail, the cab BY the front drip rail. Like that corner is in too far. If it isn't I wouldn't get too far into the skin replacement until I determined if the door is tweek'd or not... If the door fits good everywhere but the bottom rear corner I would think something has to be bent somewhere, either the cab or the door. What kind of shape are the cab mounts in? LockDoc
01-22-2017, 11:15 PM | #8 | |
Certainly not helping matter. I plan on changing them when I cut the frame to short bed. Posted via Mobile Device |
