Old 01-24-2017, 12:11 PM   #1
Ramiro0727
Hood to Cowl Seal screws
Does anybody know the screw sizes for the Hood to Cowl seal screws. i want to purchase new ones at my local hardware store.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 01-24-2017, 06:41 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Hood to Cowl Seal screws
The screws are either #8 or #10 by 1/2" long. Grab a half dozen of both sizes, you'll find a use for the left overs somewhere else on the truck.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 01-24-2017, 08:58 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
They would be #8 phillips round head.
LockDoc
Leon
Old 01-24-2017, 09:41 PM   #4
FirstOwner69
FirstOwner69's Avatar
#8 as stated above. The black one in the picture is the one used to secure the seal edge of the cowl. The shiny (polished stainless?) screw is used for the visible cowl screws. I think they are actually called pan head screws.
FirstOwner69 is offline   Reply With Quote
Old 01-24-2017, 11:22 PM   #5
LockDoc
LockDoc's Avatar
You would be correct on the pan head. I looked at my '72 and someone evidently replaced them with round head or the '72's are different. The stainless cowl screws are pan head on it but the cowl to firewall are round head. Dunno....
LockDoc
Leon
Old 01-24-2017, 11:25 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The cowl screws are the same ones used to affix the gb door hinge to the dash - grab one as an example.
Old 01-26-2017, 09:52 PM   #7
Ramiro0727
Thanks for all the replies. The #8 x 1/2" screws worked perfectly. I had to get some washers for them also.
Ramiro
Old 09-12-2023, 05:08 PM   #8
Gregski
Gregski's Avatar
glad I found this thread, forgive me for resurrecting an old one, but my '71 girl took #10 screws and half of them were still loose as a goose
Gregski is offline   Reply With Quote
Old 09-13-2023, 01:12 AM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
This gauge says #10. https://www.ebay.com/itm/27339713907...3-aO9ccudB_KQ1
Sometimes I think old #10 are a pinch smaller than new. It's a good idea to try #8 first, but I don't know, why does it seem new #8 door sill screws will install where the original screws were #10, the new paint?? Hmmm.
Never mind the #8 and 10 business, other then gr. 5 recessed hex head body bolts with spin washers, I believe..............
The cowl panel and seal mount to the cowl’s top using six phosphate #2 phillips pan head tap screws with spin washers. The screw threads are #10" x 5/8". Another option may have been phosphate recessed hex head screws with spin washers.
The cowl panel’s top rear mounts to the cowl with four stainless #2 phillips pan head tap screws and J-nuts. The screw threads are #10 x 1/2". The J-nuts are 1/2" (W) x 5/8" (T) with a 7/16" center hole to edge, and are stamped “P”.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-13-2023, 02:50 PM   #10
cericd
cericd's Avatar
Are these the screws being referenced in this thread? Would they have been painted body color or would they have been unpainted? If unpainted, what finish were they originally?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 09-13-2023, 04:08 PM   #11
Gregski
Gregski's Avatar
yes, these are the 4 out of 10, there's six more down lower where the hood meets the cowl, may be hidden under the rubber piece
just got mine from GMC Paul's
Old 09-13-2023, 08:11 PM   #12
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Those should be stainless as stated in the post right before yours.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 09-13-2023, 10:50 PM   #13
cericd
cericd's Avatar
Thanks. When I posted that, I wasn't even sure I was referencing the screws in the same area. Also, wasn't aware GM would spring for stainless screws on these old trucks. I would've thought zinc. I guess if they're stainless, I should be able to remove the gold paint and clean them up pretty easily.
Chris
Old 09-13-2023, 11:16 PM   #14
Casper42
Casper42's Avatar
BTW, is there suppose to be a "clip" on the receiving end, which the screw turns into, similar to the grill/headlight trim rings?
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 09-14-2023, 12:56 AM   #15
71CHEVYSHORTBED402
The upper stainless screws take J panel nuts, post 9. The phosphate cowl panel/seal screws tap the cowl.
Tony
