Porterbuilt engine mounts.
I have a level 3 drop member with a BBC mounts. Is there suppose to be a spacer here where my finger is between? seem like there should be one but I looked all through my bolts and parts and there were none to be had. If so I need them ASAP
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
![]() Join Date: May 2012
Re: Porterbuilt engine mounts.
I would just cut a piece of 1/2" pipe and insert it between there to stiffing the mount. Good to go, can't hurt any thing , has to make it stronger . I'm sure those holes are there for different mounting options.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
