01-25-2017, 05:48 PM | #1 |
Good or garbage?
Thinking of installing an air ride kit in my C-10. I see these being sold on eBay for $1100 anyone know if there any good?
1 - Set of Front Bag Mounts and Brackets 1 - Set of Rear Bag Mounts and Brackets 1 - Gauge Panel w/ Mounting Tab 4 - Slam Specialties SS-7 Air Bag Springs 4 - Air Lift Manual Paddle Valves 1 - Viair 40 Amp Relay 1 - Viair Pressure Switch 1 - Viair Air Tank 200 PSI 1 - Viair 444C CHROME Compressor 2 - Viair Dual Needle BLACK Face Pressure Gauges 1 - McGaughys Panhard Bar Adjustable 30 - Feet 1/4" Air Line 4 - 1/2" NPT to 1/4" PTC Bag Fittings Hardware Mounts & Bracket Specs: Material: .188 CRS (Cold Rolled Steel) Cutting: CNC Laser Finish: Raw Manufactured in the USA by Grunion Fabrication Mounting Hardware: Included Bag Specs: Specialties SS-7 Diameter @ 0 PSI - 7" Diameter @ Max PSI - 7" Stroke - 9.3" Max PSI - 250 Plate Material - Composite Min Height - 2.7" Max Height - 12" Mounting Top - 2 @ 3/8" - 16 Mounting Btm - 3 @ 3/8" - 16 Air Port NPT - 1 @ 1/2" Internal Bump Stops - Integrated Force to Collapse - 50 lbs Gauge Panel Specs: 304 Stainless Steel x .060" Thick Height: 5.125" Width: 5.25" Mounting Flange Depth: 1.125" w/ 2 Holes Manufactured by Grunion Fabrication in the USA Gauge Specs: Requires 1/8" Female NPT Compression Fitting for Installation (NOT INCLUDED) 2 - 1/8" Male NPT on Back Side Amber Color Back Light Dual Needle Chrome Bezel Pressure Measures - PSI and BAR Face Diameter - 2.0625" Paddle Valve Specs: Switch / Valve allow you to control Airflow from Tank to Bags Does not require Electrical hook up Raise or Lower your truck in approximately 8 seconds Side Push Tabs to snap in place Complete FBSS Control Air Line / Fitting Specs: 1/8" OD Air Line - Use 1/8" PTC x 1/8" Female NPT 1/4" OD Air Line - Use 1/4" PTC x 1/8" Female NPT |
01-25-2017, 07:59 PM | #2 |
Diggin The SquareLife
Re: Good or garbage?
all name brand stuff is good
01-26-2017, 01:22 AM | #3 |
Not bad priced,But talk to some of the vendors on here first you might get a better deal.
