01-30-2017, 09:58 AM | #1 |
Firewall Harness Plug Grommets
I need new grommets for the Headlight/Turnsignal Plug and the Engine harness Plug. I was looking through LMC and didn't see anything. Are these available?
I just put a New American Autowire kit in the truck, And its an AWESOME kit, but I cant get the factory type plugs seated in the super hard original Grommets. Thanks!
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
01-30-2017, 10:11 AM | #2 |
Re: Firewall Harness Plug Grommets
Ok I found em I think.. Any Reccomendation for a vendor though? I should know by now that Google is your friends.
01-30-2017, 10:39 AM | #3 |
Moderator
Ebay/Summit: http://www.ebay.com/itm/391131380023...%3AMEBIDX%3AIT
Summit: https://www.summitracing.com/search?...owire%20500566 http://www.ebay.com/itm/331402890469...%3AMEBIDX%3AIT https://www.summitracing.com/search?...owire%20500564
01-30-2017, 03:16 PM | #4 |
I saved this link. I haven't bought from them, but it looked like they had a lot of these plugs.
Regards, Steve http://www.dreamershotrods.com/Elect...Kit-6Wire.aspx |
01-31-2017, 06:11 PM | #5 |
I'm just glad to be here!
Classic Parts has them:
Engine Harness: http://www.classicparts.com/1960-66-.../#.WJEKU2fnY5s Main Harness: http://www.classicparts.com/1960-66-.../#.WJEKsGfnY5s Firewall 6pc. Set: http://www.classicparts.com/1960-66-.../#.WJEK0WfnY5s American Autowire also has them Main/Turn Signal: http://www.americanautowire.com/shop...pass-thru-4911 Engine: http://www.americanautowire.com/shop...pass-thru-4910 Note, these are just the grommets!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-01-2017, 09:09 AM | #6 |
thanks Aggie, that's exactly what I needed. I ordered from classic parts.
02-01-2017, 01:31 PM | #7 |
Heat them when you put them in. It makes the much easier to work with.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-01-2017, 03:04 PM | #8 |
I put them in boiling water about 10 minutes before I needed them, wore gloves and they went in pretty well.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
