What a thousand bucks and an education looks like
I decided a couple of months ago that I wanted to put a stock bench seat in my '68 c10. It had a seat out of a late model dodge pickup in it, but I never liked being able to see the headrests through the back window.
I did a little research and learned that there were two different kinds of seats (full foam/spring foam). I started searching on cl until a found a seat that was out of a '70 4x4. I met the guy and looked at the seat, flipped it over and could see the bottom was all foam. I handed him 200 bucks and walked out. Mistake #1......this will come into play later on. I then ordered a 350 dollar houndstooth cover from PUI. I was gambling the foam would be okay in the seat I bought. The seat cover came in after a couple of weeks. In the mean time, I stripped the seat and decided the foam would be okay. I started to put the new cover on and immediately could see it wasn't going to fit. I disassembled the seat further and discovered the seat I bought was out of a '79......Now I'm 550 bucks into this deal and there isn't any turning back now. A couple of days later, I was telling my dad about it, and he said he had a stock bench I could have in the yard of his shop. I checked out the seat, flipped it over and it was a full foam bottom.....score me! After stripping the seat, my dad tells me I need to take it and get it sandblasted and powder coated. I'm thinking to myself, I'm 550 bucks into this deal, I'll be happy with a wire brush and rattle can. However, you can't argue with your dad when he's giving you something, so off to powder coating it goes. 100 bucks later, I pick it it. In the mean time, I knew the new seat was going to need foam so go ahead and order it. 300 bucks. After getting all my parts in, I start assembly, and I discover there aren't two kinds of seats, there are three. And the third one is what I have. Full foam bottom, spring foam back. At this point, I'm not going to be deterred, so I find a full foam back to compare my spring foam to. I discover I can remove the whole spring section of the seat and it modify my new foam and it might just work. So this is what I do. After removing the spring section and cutting down my foam, and paying someone to repair a minor tear repair on the back of the new cover (50 bucks), I am in business. It came out decent, and I did it myself. I still plan to cut down the frame because I sit too high, but that's wont be a big deal..........I hope. |
Re: What a thousand bucks and an education looks like
Sorry for your agrivation, but it looks nice!
Greg |
ill give you 300 for it. haha looks great
I had basically the same story minus the new foam, but it sure does feel good knowing the job was done right!
turned out to be pretty nice looking, but costly
Florida Edition
![]() ![]() Join Date: Oct 2010
Hats off to you for pushing through.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Yours, too!
Although I went for the water blasting, rattle can primer and semi gloss black. I used burlap against the springs on the bottom and the mesh on the back and a dark gray heavy felt in between the burlap and the foam. Mine is a Spring bottom(thin foam) with full foam back, but I have since purchased a foam bottom/foam back seat which I will swap out in a few months. I get to do it all over again! Hey! |
#10 | |
Funny story !
I'am not laughing at you I'am laughing with you ! It really looks nice, good job . Seems like your story is like most of ours , always a curve ball in there somewhere ! Thanks for the laugh ! |
Similar story here... Previous owner had an "upgraded seat" from a '73-on square-body truck. It was a mouse-piss mess.
Found a correct 67-72 seat frame locally for $50. Thought I could use the foam from that, but it was chewed to hell from mice as well. Ordered new foam and a new seat cover. $800 later I have a beautiful new seat. (Only paid $1200 for the entire truck...LOL)
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
#15 |
That seat came out nice
'71 ![]() '86 K30 C&C '89 Iroc-Z |
#16 |
#17 | |
#18 |
Oh yeah, forgot to mention... The seat looks great!
#19 |
I like the 67 Camaro...
Do you have a 1972 Plaid Pickup?http://67-72chevytrucks.com/vboard/s...d.php?t=635040 Do you have a 1972 Plaid Suburban?http://67-72chevytrucks.com/vboard/s...d.php?t=635033 Do you have a 1972 Plaid Blazer?http://67-72chevytrucks.com/vboard/s...d.php?t=635035 Your Service Manual: http://67-72chevytrucks.com/vboard/s...d.php?t=558016 SPID Thread http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#20 |
Hey, thanks! That was my first car. We built it when I was in high school (20 plus years ago).
Here's a better picture of it. |
#21 |
The end result looks great, and you can't put a value on such a good education.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#22 |
I looked around in the KC area to get the front seat of a Studebaker recovered (not even to original spec) and the front seat was going to be $1200 and the rear seat $1000. I about choked, so I found blanket covers and tied them really tight and duct taped the bottom part of the seat before I put it on.
You did ok. It looks GREAT!
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
#23 | |
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
#24 |
Not sure I could have avoided having a seat burning party with all of that frustration. Good work pushing through. The seat, the truck and the Camaro all look really nice.
#25 |
Oh, fire was discussed at great lengths.
