Old 01-31-2017, 05:23 PM   #1
AirSpeed
AirSpeed's Avatar
Th 350 needs to warm up before going into gear
Had my TH 350 in my K1500 rebuilt a few years ago and every winter I have to warm up my truck for 20 minutes before it will go into gear. It gets pretty cold here, down to -16 F a few weeks ago but usually gets to around 14/20 degrees in the morning. Is this normal? Anyone else experience this?
AirSpeed is offline   Reply With Quote
Old 01-31-2017, 06:26 PM   #2
demian5
demian5's Avatar
Re: Th 350 needs to warm up before going into gear
You don't mention fluid level and/or condition being OK. I would check that first.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-31-2017, 06:49 PM   #3
kaycee
kaycee's Avatar
Drop the pan and see what it looks like ,maybe time for a rebuild,could just be a filter need s changed
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-31-2017, 08:12 PM   #4
AirSpeed
AirSpeed's Avatar
Fluid is full and so clean it's tough to see it on the dipstick.
Old 01-31-2017, 06:50 PM   #5
scooterpimp
scooterpimp's Avatar
Alot of the time delayed engagement is due to weak/worn,dried up seals. Would recomend checking fluid or servicing trans with filter. Then go from there.
scooterpimp is offline   Reply With Quote
Old 01-31-2017, 08:10 PM   #6
Keith Seymore
Keith Seymore's Avatar
Do you have a deep/cooling trans pan installed?
They can cause what you are describing.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-31-2017, 08:10 PM   #7
AirSpeed
AirSpeed's Avatar
Fluids are good, tranny was rebuilt a few years ago by a respected shop. Shifts nice and solid once warmed up but on cold mornings it takes about 20 minutes. We've had a colder winter this year so I'm wondering if that's the issue, it's happened a few times over the last couple years but seems to happen more this winter. I work from home so I don't have a lot of miles on the tranny since it was rebuilt.
Old 01-31-2017, 08:39 PM   #8
cherokeejohn
cherokeejohn's Avatar
Mine had to be filled all the way to the full line on the dipstick to go into gear at all. If it was only halfway on the checkerboard, it would do the same as yours at times, others it wouldn't engage at all.I also recommend adding a bottle of Lucas Trans Additive, That stuff has done wonders for me with several vehicles, all GM of course, 3 700R4's and 2 TH350's, It's about the consistency of warm honey. I use all Lucas Products in all my vehicles, fuel, oil, diff's, and trans. Worth a shot, as it's a helluva lot cheaper than a rebuild or replace. Hope this helps
72 C/10, LWB, 5.7, Auto, with A/C
F.B.I = Full Blood Indian
Appalachia/Eastern Cherokee,"Tsalagi"
cherokeejohn is offline   Reply With Quote
Old 01-31-2017, 09:02 PM   #9
Bigdav160
Bigdav160's Avatar
The seals are old and hard. I seal swellling additive will get it working for a while but be prepared to overhaul it someday soon
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-31-2017, 11:02 PM   #10
AirSpeed
AirSpeed's Avatar
Would they dry out in only a few years? It was rebuilt about three years ago and it doesn't have a lot of miles on it.
