Old 02-01-2017, 05:38 PM   #1
rdhowe2006@yahoo.com
rdhowe2006@yahoo.com's Avatar
Gas Tank
Looking to purchase a new or good used gas tank for my 1970 C-10 Pick-Up? Also will need the sending unit. Also any idea to keep or slow down the moisture inside the tank? Beside having to keep it full of fuel all the time? Any help would be appreciated. Thanks
rdhowe2006@yahoo.com is offline   Reply With Quote
Old 02-01-2017, 05:54 PM   #2
onebigjohn
onebigjohn's Avatar
Re: Gas Tank
Try this
http://www.ebay.com/itm/OER-FT5003A-...3D250671776305
And this
http://www.ebay.com/itm/6428362-OER-...id=p5731.m3795
"I pawned my Hanso"
"Hold my beer, Watch this"
onebigjohn is offline   Reply With Quote
Old 02-01-2017, 09:35 PM   #3
CST10
CST10's Avatar
Re: Gas Tank
I bought my gas tank from brothers trucks and the sending unit too. Fit was great. Dropped right in.
Yes, best to keep it full of gas if leaving for long periods with moving it around. Only way I know to keep the rust from starting.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 02-01-2017, 09:38 PM   #4
In The Ten Ring
Re: Gas Tank
My tank is OEM and it flash rusted WITH a topped off tank.
I had it "renewed" and we will see if that does the trick.
If parking for a long time, I would suggest draining the tank fully and letting the engine run until it quit.
Would that cause "vapor lock?"
In The Ten Ring is offline   Reply With Quote
Old 02-02-2017, 05:49 AM   #5
Boog
laying low
Boog's Avatar
Re: Gas Tank
I believe all stock gas tanks are made of galvanized steel to resist corrosion. However today's ethanol/gas blends do tend to be corrosive in nature. Engines that sit for extended periods of time are more affected than those run regularly. Mississippi shouldn't be any more susceptible to in tank moisture buildup than any other locale.
There are fuel stabilizers and in tank coatings available to help keep them clean.
You can use only high test grade gas to help prevent corrosion as it is ethanol free.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-02-2017, 06:53 AM   #6
James the III
Re: Gas Tank
Maybe where you're at..
I have not looked at the 1972 tank set up... but I think most of the issue is the open"vented" nature of the fuel system.. ethanol draws in moisture .
You'd not keep your brake master open because of this.. fluid collecting moisture..
If I was changing tanks(buying) I think I'd look at what the 72 set up is. and how sealed it is.. i.e. charcoal can /etc..
Wonder if anyone re-pops this in s.s. .. not that ,that will stop the fuel from sucking moisture..
James the III is offline   Reply With Quote
Old 02-02-2017, 08:36 AM   #7
biketopia
Re: Gas Tank
Yea...only non ethanol gas would be stuff that is labeled as ethanol free, like if you have a lake near by, lots of times marinas and stations near the water have ethanol free fuel. Plus running high tes in an engine that doesn't have high enough compression and way advanced timing is not only a waste of money but will carbon up up your engine for no reason.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 02-02-2017, 08:40 AM   #8
Ken B
Re: Gas Tank
I'm also looking for a fuel tank for my 70 C30. Will the tank in the Ebay link work for mine? The Ebay tank says its for a truck with EEC which I don't have on my 70. What are the differences if any?
Ken B is offline   Reply With Quote
Old 02-02-2017, 02:11 PM   #9
68blazer
68blazer's Avatar
Re: Gas Tank
I have two stock gas tanks ready for purchase. one has a sending unit the other doesn't but both are in Oklahoma city
68blazer is offline   Reply With Quote
Old 02-02-2017, 04:27 PM   #10
Re: Gas Tank
Are they new? Also can you send pics and price to ship to 39666?
Old 02-02-2017, 11:54 PM   #11
Question Re: Gas Tank
Anyone know what company would have the lowest priced gas tank to purchase? I purchased a tank about 2 years ago and it already has rust in the tank!
Old 02-03-2017, 06:40 AM   #12
Boog
laying low
Boog's Avatar
Re: Gas Tank
I bought one last year from LMC Trucks. Brothers Trucks sells them. I'm sure there are others. I found between Brothers and LMC price and freight to me the total cost was almost the same.
http://www.lmctruck.com/
http://hhclassic.com/
http://www.topbananaparts.com/
http://www.brotherstrucks.com/
Browse the vendors who support this board too. They sometimes offer specials and discounts to members.
Boog
primer is finer
Old 02-03-2017, 07:20 AM   #13
projectking
projectking's Avatar
Re: Gas Tank
Have a radiator shop boil it and coat the inside
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
