02-06-2017, 04:56 PM | #1 |
Can the shift indicator pointer be adjusted?
When my truck is in Park the shift indicator is way off to the left. Is there any way to adjust it so it is closer to the 'Park' lettering?
While we're on the topic of shifters, is there any way to tighten up the feel of the shifter? It's kind of vague and doesn't really click in to each gear. The shift lever is good and tight since I replaced the pin and the plastic bushing on the end of the lever. I'm guessing the problem is wear related so maybe that just means replacing some parts, but I was hoping to get confirmation from you all. Thanks!
Dennis '70 CST/10 '55 Bel Air wagon |
02-06-2017, 05:18 PM | #2 |
Re: Can the shift indicator pointer be adjusted?
Mine was really vague and kind of sluggish feeling, so I thoroughly lubed the column from the top with a spray silicone lube, and sprayed the shifter mechanism at the bottom of the column on the engine side of the firewall. Feels much crisper now, but still not perfect.
Not sure about the alignment of the pointer, but someone else will jump in on this I bet.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
02-06-2017, 05:23 PM | #3 |
Maybe this will help...
http://67-72chevytrucks.com/vboard/s...d.php?t=555640
"I pawned my Hanso" "Hold my beer, Watch this" |
02-06-2017, 09:49 PM | #4 |
I removed the gear indicator housing, can someone tell me what this metal bump is for under it?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-06-2017, 09:52 PM | #5 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Light for the indicator.
02-07-2017, 11:37 AM | #6 |
how can the bulb be changed? is the bulb in this silver thing in the hole on the column? I had rotator surgery and can't use my right arm for 4 more weeks and it is killing me not to be able to go out and tinker....
02-09-2017, 05:08 PM | #7 |
Custom Sport W/T
The metal cover should just pull off and the bulb and socket will be underneath hopefully. The bulb socket attaches to the underside of the turn signal switch with a screw and it has a prong that contacts the metal underneath for a ground. These are known for losing the connection to ground.
02-07-2017, 11:50 AM | #8 |
Wait, there is a light AND the fiber optic line for the pointer?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-08-2017, 10:01 AM | #9 |
Had the same issue with mine. I used a 2spd column on mine and I think that was the difference for me I also had a 3 spd and the bolts circled in red were drilled at different spots. Well I already had the 2 spd restored and painted so no way was I going to restore another column. I re drilled the holes and elongated them to make it adjustable.
I am also using a 700r4 with a lokar linkage and tried adjusting and it would not even come close. Now Everything is perfect and can manual shift to every gear. When I shift to 1st it is a little right of the l1 which for me is perfect.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
02-08-2017, 08:57 PM | #10 |
02-06-2017, 11:10 PM | #11 |
You can adjust the linkage under the hood to get your indicator pointing correctly. Just loosen the locking nut on the linkage and move it up or down on the long rod until the indicator points to the correct position.
When I bought my truck the shifter didn't work smoothly, really hard to get it in park. I drove it like that for years then one day I removed the gear shifter and found the ball on the end of the shifter wasn't in the column correctly. I greased it and put it back the way it was suppose to be and it has been working right every since. |
02-09-2017, 04:50 PM | #12 | |
