sourcing a driveshaft yoke for a 1949 3100.
i hope this is the right place to post this. i did a search but could not find anything. i need the driveshaft end of the yoke for a 1949 3100 pickup. i got the Okie Bushing but the yoke is worn and fits too loose. i have checked around and have had no luck in locating a new one. i would guess most used ones would be worn and no better that what i have. i need to locate one. i am doing a off frame restoration and put in the patrick's r&p.
thanks for any help you can offer on this.
1949 chevy 3100, 5 window 1992 chevy k1500, extended cab, short box 5.7l 1996 chevy k1500, extended cab, long box 5.7l 2001 chevy impala ls 3.8l 1965 honda s90 |
![]() Join Date: Sep 2016
Re: sourcing a driveshaft yoke for a 1949 3100.
classic parts.com has a U Joint repair kit that might be what you need. If not, try classic industries. They have a part #G13114 27 spline driveshaft yoke. Possibly chevs of the 40s has both ends of the yoke but it looks like its back ordered... item #591642
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
![]() Join Date: Jul 2014
If you post or send a pm of what you got I might have an extra one that you can have.
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
