02-07-2017, 05:51 PM | #1 |
OE LS Air Cleaner & Tube Options
I'm looking into options on air cleaners and am set on using an OE takeoff but after some ebay browsing it's clear that there are several different designs. Has anyone investigated which ones fit best and/or look cleanest?
1968 LWB C20 / AC / Wood Bed |
02-07-2017, 09:01 PM | #2 |
meowMEOWmeowMEOW
Re: OE LS Air Cleaner & Tube Options
I think Andy is using a stock airbox adapted over to his swap. I'll see if I can find his thread.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-07-2017, 11:28 PM | #3 | |
So far I think I've found that some silverados have a pretty inconspicuous tube while suburban/tahoes have an addition resonator that shoots off to the driver side.
02-07-2017, 11:53 PM | #4 |
meowMEOWmeowMEOW
Why do you want to go with the stock tube exactly? (cost, or stock appearance?)
If its the appearance, you can get intakes from stock-looking plastics pretty reasonably priced. Almost all of the truck intakes either had a goofy flat section over the fan, a big de-resonator, or the awkward scrunchy bit at the end. Something like the H3A intake could be made streamlined if you cut the wart off of it and patched the hole.
02-08-2017, 01:09 PM | #5 | |
02-08-2017, 02:05 PM | #6 |
I went straight out the front and kept it simple.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
02-10-2017, 11:03 AM | #7 |
Are you using a MAF with that set up?
02-10-2017, 04:30 PM | #8 |
Yes, i have a coupling right off the intake to the MAF, then the filter is coupled directly to it.
My DD gauges show intake temps. It is supposed to be high 60s here tomorrow. I'll see what my temps are after driving around for awhile. Does anyone else have intake temp readings that has a intake mounted on the fender?
02-08-2017, 07:05 PM | #9 |
I'd definitely do that for mockup and it sure looks nice but that's really probably the worst placement in terms of sucking in hot air; it's not only right next to the hot engine but also right in front of the hot air blowing through the radiator.
Off topic, what radiator is that?
02-08-2017, 11:03 PM | #10 |
Will this work for you?
02-09-2017, 01:11 AM | #11 |
I use the factory Silverado ones, they seem to fit pretty good to me and they're damn near free!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-09-2017, 01:16 PM | #12 | |
I'm looking to route to the driver's side but maybe. What filter does it take, how does it mount, and how much does it cost?
Edit: just realized that your thread is one that I've read like 3 times and am using as a reference -- I just found your mounting details at [1]. I actually asked you recently in that thread about your A/C details -- I'm going to do the same eventually but use a Trailblazer compressor and motor mounts. I still don't understand much about the A/C system overall and how the components will work together but A/C is low priority for me now and I figure I can learn about that after my swap is complete. [1] http://ls1tech.com/forums/conversion...l#post16872722
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 02-09-2017 at 01:24 PM. |
02-09-2017, 08:23 PM | #13 |
The air box i got from a 1991 Lincoln. cost 10.00 new filter 6.00 made a bracket and mounted it to the core support. Re mounted my horn lower on core support.It gets fresh air from louvers in core support. Hope that helps
02-10-2017, 09:27 PM | #14 |
02-10-2017, 10:10 PM | #15 |
02-27-2017, 05:52 PM | #16 |
