Old 02-08-2017, 04:15 PM   #1
jweb
jweb's Avatar
Gas Smell/ Tank vent ??
On my '51 every time I fill it up with gas it smells really strong. I was thinking about adding some type of vent.
Will it help? If so any suggestions of what to use and where to run it?
Any other ideas besides moving the tank, I really don't have space under the truck for that.
jweb is offline   Reply With Quote
Old 02-08-2017, 05:25 PM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Gas Smell/ Tank vent ??
Venting the gas tank is for the ease of filling the tank to relieve the air as you are adding the gas. but it would help for the smell issue. I assume the tank is behind your seat?? the only thing I can come up with is to remove the tank, dump the gas, and add a vent line to the filler tube. This will allow you to fill the tank and the air will will escape thru your vent line.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 02-08-2017, 07:09 PM   #3
jweb
jweb's Avatar
It is behind the seat. The stock filler neck has a vent for filling. I've never had an issue with that.
My stock sending unit isn't being used since my LS swap. So I wondered if I could use that line to add a vent or a charcoal canister. Maybe I just need to reseal it.
Old 02-08-2017, 07:58 PM   #4
vintovka
vintovka's Avatar
I moved my tank to under the bed. Having the tank in the cab was never a good idea. If you look at gasoline toxicity you might be amazed. I checked my cab back when the tank was still in it with a hydrocarbon detector that read down to 1 PPM. Even when you can't smell it, It was still present in a closed up cab.
vintovka is offline   Reply With Quote
Old 02-08-2017, 10:53 PM   #5
jweb
jweb's Avatar
I wish I would have done that years ago but never liked the idea of a bed filler. I use my truck to haul all kinds of stuff. I would do a '48 style tank that fills through the bedside but it would never fit with my trailing arm suspension. Also would have to weld the original filler hole and try to match the paint.
So I'm just trying to find some creative idea. Maybe I'll just build a box around it and try to seal it really well. That probably won't do much good.
Old 02-10-2017, 12:01 PM   #6
mobileortho
mobileortho's Avatar
i moved my tank to under the bed. Having the tank in the cab was never a good idea. If you look at gasoline toxicity you might be amazed. I checked my cab back when the tank was still in it with a hydrocarbon detector that read down to 1 ppm. Even when you can't smell it, it was still present in a closed up cab.
ditto!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 02-09-2017, 12:45 AM   #7
vintovka
vintovka's Avatar
Bed fillers seem a PITA so I used a 25 gallon suburban tank and ran the filler to the drivers side fender. The old pic shows the cap location . The bed off shows the replacement tank in position but the filler hose is just laying on the fram. The 85 Sub tanks run about 60 shipped and the sender in another 30.
Old 02-09-2017, 11:08 AM   #8
jweb
jweb's Avatar
Bed fillers seem a PITA so I used a 25 gallon suburban tank and ran the filler to the drivers side fender. The old pic shows the cap location . The bed off shows the replacement tank in position but the filler hose is just laying on the frame. The 85 Sub tanks run about 60 shipped and the sender in another 30.
That's a pretty good setup. I'm not sure how that fill location would work with a low truck. Also, any tank under the truck I would probably have to change my exhaust. Then there's the fuel pump, fuel line and return line which can get expensive.
Old 02-09-2017, 02:04 AM   #9
mr48chev
mr48chev's Avatar
If you use the original pickup tube on the sender as a vent you have pull the sender out and cut the pickup tube off or you just created a possible siphon hose setup. Running the canister and venting to it does let you install a non vented cap to cut down on the fumes escaping there while venting the tank so you don't create a vacuum in the tank while driving.. Actually you vent the tank so it allows air in to replace the gas that you pumped out otherwise you create a vacuum and it can and will suck the sides of the tank in before the engine quits in some cases.
Personally I am not a fan of tanks behind the seat even though over the years I've had a lot of trucks with seat tanks. You always run the chance of a leak or fumes plus you lose the space.
On a truck that I didn't want to disturb nice paint or what not I think I'd just invest in a simple locking gas cap, put it on the filler neck in the cab and stick the keys in my hide my extra keys box and call it good. A guy could cut he filler neck off short and cap it and put it back too but some may not want to risk the painted area around it by disturbing it.
I don't like the filler in the floor of the bed either. It's that way on my truck now is a real pain as even though I don't plan on hauling anything except travel gear in the back moving stuff to get to the gas filer isn't something I want to do an I plan on some serious and long road trips with it when it is done.
My ongoing truck projects:
Old 02-09-2017, 10:49 AM   #10
dsraven
if you consistently smell gas after a fill you should check for a leak in the system. especially if you have an old tank with a possible rusty bottom or leaky hose connection. I am not a fan of the seat tanks either, for the hydrocarbon reason, the sitting on a gas can reason and also for space. I have seen some guys' mods that place the tank under the truck and the filler inside the wheel well. a bit of a pain but do-able. also some guys have put the filler behind the lic plate or above the hitch. that usually means a lower tank though. how about an under bed tank with a filler behind a tail light. use muffler pipe to connect the dots from the filler, sourced from a wreck, to the tank. get a tank with a vent and grab the carbon canister as well.
Old 02-09-2017, 12:06 PM   #11
vintovka
vintovka's Avatar
Was thinking about the whole idea of in cab gas tanks. This is a design which requires drivers to drive around with 20 gallons or so of highly flammable liquid which is also a known carcinogen. Uhh hello?
Old 02-09-2017, 01:43 PM   #12
jweb
jweb's Avatar
I agree, it's an odd design. Who knows what they were thinking back then.
I'm going to get under the truck and see if there's any way I can fit a tank without changing the exhaust. If the tank will fit over the exhaust, I will add some kind of heat shield and maybe wrap the pipes in that area. Then I can do what mr48 said and just leave the old filler and add a locking cap to it for now.
I'm on my third engine and third exhaust setup, maybe it's time for a third fuel tank.
Old 02-09-2017, 02:18 PM   #13
vintovka
vintovka's Avatar
I thought about adding one of those combination toolboxes/tanks to bed, Yes it takes up space but so does carrying a spare. No easy fix. There are many things that we used to think were safe.
If you like the smell of gas read this:
https://www.cancer.org/cancer/cancer...s/benzene.html
Old 02-09-2017, 03:37 PM   #14
joedoh
joedoh's Avatar
check your filler tube gasket, I tried to search for it but someone else mentioned this a couple years ago (it might have even been another forum is why I cant find it) and it was mentioned to change the filler tube gasket, it was made of a different rubber and even a single drop running off the edge of the filler would wick right through to the inside between the tube and the gasket.
Old 02-09-2017, 04:19 PM   #15
jweb
jweb's Avatar
The filler neck, hoses, neck grommet and gas cap are just a few years old. I've had the sending unit out a few times so that gasket may be damaged. Not sure where to get a replacement.
Old 02-09-2017, 08:14 PM   #16
joedoh
joedoh's Avatar
well, thats what i was saying, the new replacements were made of a rubber that werent gas and oil impervious. it was the grommet on the body, but maybe the filler neck too?
the sender gasket is a good idea too
Old 02-09-2017, 10:46 PM   #17
dsraven
so, when and for how long does it smell like gas after a fill up? you fill, drive away and it smells like gas for a short time but before you get home it has stopped smelling? you fill and it smells like gas till it get down to 3/4 tank (or whatever) before it stops smelling like gas? it smells like gas all the time? it smells like gas at 1/2 a tank if you go around a corner hard and the fuel sloshes in the tank? it smells like gas on a hot day but not a cold day? the reason I ask is because sometimes the straps that secure the tank or possibly the contact area under the tank can hold dampness and cause a pinhole. for all the time it takes to remove the tank it may be a good idea to yank it out and check everywhere for a gas leak trail. when I got my 57 it smelled like gas really bad because the tank had a pinhole in the bottom where it contacts the floor seating area. the farmer would just put enough gas in it for the purpose he had at the time. the rest would slowly leak out onto the cab floor and evaporate. probably kept the mice out. he wasn't worried about it. the cab had to be pressure washed to get the stink out. I was dismantling the truck anyway so it was coming apart.yours is maybe not gonna get that treatment.
Old 02-09-2017, 11:16 PM   #18
jweb
jweb's Avatar
I would say it smells really strong until 3/4 tank. I had the tank out last year when I did the LS swap. Replaced the cap, filler tube, grommet and hoses then.
I think I will check for room under the truck. If there's no room, I will try the sending unit gasket and check the plug I have in the stock pick up tube.
Old 02-09-2017, 11:26 PM   #19
mongocanfly
mongocanfly's Avatar
Where I work we have hand held vapor detectors..if you could find someone that has one you could find out real fast where the fumes are coming from..a fire dept may have one..
Old 02-09-2017, 11:43 PM   #20
vintovka
vintovka's Avatar
Originally Posted by mongocanfly View Post
Where I work we have hand held vapor detectors..if you could find someone that has one you could find out real fast where the fumes ar coming from..a fire dept may have one..
Good idea, And what i have done. Bottom line is gas fumes still wind up in the cab as components penetrate rubber and other materials. No vehicle manufacturer today would EVER put a gas tank in an enclosed passenger area. The way the big C is taking folks makes you think about reducing your exposure where ever possible including during fill ups.
Old 02-09-2017, 11:55 PM   #21
jweb
jweb's Avatar
I wonder if this works
http://www.ebay.com/itm/Combustible-...-/111961052522
Old 02-09-2017, 11:51 PM   #22
nvrdone
when I still had an in cab tank, I had the same gas smell. plus when I filled the tank, it all ways spilled over & ran down the side of the cab. On the filler neck there is a small hose for a vent. I put a "t" fitting into that & ran a hose thru the floor into a charcoal canister mounted on the frame rail. didn't have any more gas smell after that.
nvrdone is offline   Reply With Quote
