Old 02-13-2017, 09:04 PM   #1
STRUTYOURSTUFF
1965 c10 parking light/directional lights
Hoping someone can help me out here. Have a 65 c10 no power going to the front parking /directionals. Checked the spec sheet but can't figure it out. The plug coming out of the firewall has no power. I have head lights / rear lights. No power to the flasher plug. Really would like to know how it really works. Can someone explain. Thanks guys you Rock!
STRUTYOURSTUFF is offline   Reply With Quote
Old 02-13-2017, 09:29 PM   #2
luvbowties
luvbowties's Avatar
Question Re: 1965 c10 parking light/directional lights
One ODD tidbit that may help: "parking lights" on 65-66 pkps. do not burn with headlights on--came that way. 'bout all I can help u with, as elec. is not my gift with questions and answers, but somehow get it done "in person".
Sam
luvbowties is offline   Reply With Quote
Old 02-14-2017, 08:27 AM   #3
PGSigns
PGSigns's Avatar
Go to the FAQ section and scroll down to the wiring section and you can get the wiring diagram for your truck. That will help you see how it all is wired.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-14-2017, 08:46 AM   #4
STRUTYOURSTUFF
Thanks for the advice guys. Jimmy I've check the wiring diagram. I have to check the light switch. I think I had it pulled out all the way. Foothills said that the parking lights wont be lit with the head lights on. I thought they were similar to running lights. I might be just the switch position. I will check later in the day. Hoping its just a rookie mistake. Thanks guys I'll keep you posted
Old 02-14-2017, 02:29 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Pull the switch half way out for the running lights. If they Still don't work...check the grounds. Most common problem is grounds.
Old 02-15-2017, 09:07 PM   #6
STRUTYOURSTUFF
Hey guys thanks for the help. Got the parking lights up and running! Still have to get the directionals working. Any advice? I changed the flasher. There is power there. Thinking it maybe in the directional switch. Also when I apply the brakes my drivers side brake light lights and the passengers side seems to dim. Any help would be very appreciated. Thanks in advance
Old 02-16-2017, 07:37 AM   #7
PGSigns
PGSigns's Avatar
Go through and put a ground strap from your hood to the body. Put another one from the rear cross sill on the bed tot he frame. If you are working on a fleet side pull your tail lights out and put a ground from the housing to the bed. If a step side put a ground from the stud coming out of the tail light to the bed. This will improve things. Then on the turn signals check the plugs on the column to make sure there seated good. As you go clean and reseat the connections. See where this gets you and let us know.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
