Door glass question
I'm looking to replace the door glass in my 72 Jimmy. I cannot find any supplier specificlly selling k5 glass. This is probably a dumb question.... is truck windows the same as blazer/jimmy door glass??
Thanks for the help, Eric |
![]() Join Date: May 2007
Re: Door glass question
Same.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
![]() Join Date: Jun 2004
Curious to know how you make out. Both my door glasses were changed by PO and now both lack about a 1/2" of going all the way up and I can't see how to correct this.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
#4 | |
There might be some adhesive or similar where the glass attaches to the regulator that is prohibiting full travel. I have this sometimes on my blazer, once the bottom of the window reaches the door seals I have to give it an extra bit of effort to get it up all the way.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
69-72 I've had the doors apart. Couldn't see anything wrong or any way to adjust. My Jimmy is 71 but has the door stiffening screws by the vent window, so I'm assuming the doors are 72.
![]() Join Date: May 2011
71's have the vent window screw also just plastic and the hole is just a hole. The 72 doors the hole is countersunk or tapered whatever you want to call it.
2WD Jimmy
![]() Join Date: Mar 2005
I had the same problem as 4oldcars. Aftermarket was actually shorter than OEM. (I layed one over the other to compare) I ended up getting NOS glass from Wes at Classic Heartbeat. The alternative might be to have custom flat glass cut to match original pieces.
I have a couple sets of door glass I've saved over the years. If you wanted to go with some OEM stuff instead of aftermarket. I'm local to you too....over in Auburn. If your interested shoot me a message.
#9 | |
Eric |
I'll have to look to see if I have any tinted or if they are all clear sets. Have 3 sets of side glass and an extra set of truck doors I'm saving incase I need to cut down a pair for my Jimmy.
#11 | |
I have one set of tinted glass. You'd have to check them out to see if they were up to your standards. The sash on both of them have some rust, but are solid. The glass looks to be scratch free, it's real dusty from sitting on the loft in the barn...once it gets washed it'll probably clean up fine. |
#12 | |
Eric |
toomany - - I don't think my glass is aftermarket. I could be wrong. Glass/channel/mechanism/etc all appear original.
#15 |
hemi43 - Duh
