02-15-2017, 07:24 PM | #1 |
Bought a 4wd frame what are the differences
Bought a frame for a 1974 c10 that is 4wd what are the frame differences between that and a 2wd truck I have a longbed Donor truck can I convert this frame to 2wd?
02-15-2017, 09:59 PM | #2 |
Re: Bought a 4wd frame what are the differences
02-15-2017, 11:09 PM | #3 |
I've know a handful of people to strip the frame down and convert to 2wd with no issues. Looks like the link above proves it's pretty much the same frame.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
02-16-2017, 01:25 AM | #4 |
02-16-2017, 07:56 AM | #5 |
The front end is a lot of work.basicly the front needs to be stripped down to the frame rails even the steering boxes are different.The rear i think its different springs or shorter not 100% sure on that.
02-16-2017, 10:50 AM | #6 |
Yeah basically all steering and suspension
02-16-2017, 11:11 AM | #7 |
02-16-2017, 05:36 PM | #8 |
Junior Member
I agree with andrewmp6.... That's a lot to do. 2wd frames are usually plentiful. Why go through all the work??
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
02-16-2017, 05:49 PM | #9 |
02-16-2017, 05:45 PM | #10 |
Cut some rivets and drill away! It'll be something to be proud of
02-16-2017, 09:46 PM | #11 |
Another issue is there's a reason things are riveted to the frame, not to mention 4x4 frames are relatively rare since what 10% od trucks are 4x4?
The rivets fit the holes w/ no clearance and are actually a pain to remove. Bolts will fit loosely and will have threads in contact w/ the frame and bracket. Thus, when moving, the truck will flex that bracket/frame/bolt and try to loosen the nut, break the bolt, and make the hole bigger. Nothing will stop the process other than not driving. Do you want your suspension attached to the frame by bolts? |
02-17-2017, 12:26 AM | #12 | |
resident oilfield trash
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
02-16-2017, 09:58 PM | #13 |
Well if anybody know a person who wants a 4wd frame I'll trade it for a 2wd or just sell it outright for a good price
02-16-2017, 10:23 PM | #14 |
What were you plans with the truck? You might also consider shortening the longbed frame. There are many write ups on that.
02-16-2017, 11:04 PM | #15 |
I'm thinking about doing that but now I have to off load this frame
02-17-2017, 08:00 PM | #16 |
driving is in my blood
I have no problems using bolts for pretty much anything other then putting aircraft skin together.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-17-2017, 11:39 PM | #17 |
I've also used bolts on many spring hangers and had no problem but I also drilled the rivet holes out to a 1/2" and use grade 8 bolts & nuts
