02-17-2017, 02:35 PM | #1 |
Think i got my wheel dialed in
Think i finally got it were it needs to be!
Allen |
02-17-2017, 04:07 PM | #2 |
Re: Think i got my wheel dialed in
Well centered there.
02-17-2017, 04:44 PM | #3 |
Looks good there.
Kim |
02-17-2017, 04:59 PM | #4 |
Thanks Guys,
Embarrassed to say I had it in at the mark Flat out engineering plans calls for (from front of frame back to center of crossmember 27.5 inchs) well i put it in and thought that i had the wheel centered and welded it in, Well after double checking after i was over zealous with welding it in i found that i was an idiot and had the wheel to far forward, I couldn't live with it so cut it back out and hate to say the Mistake cost me $211.00, had to buy new coil spring mounting brackets and C notch piece's. After My Son Convinced me to move it back 2 more inchs I am allot happier with it and it would make seance as 58-9 frames are suppose to be 2 inches longer at the front frame horns? Allen |
02-17-2017, 05:53 PM | #5 |
Yep ..looks good from here..
02-18-2017, 04:22 AM | #6 |
Better to spend the money than have to live forever with something that annoys you every time you look at it.
02-18-2017, 09:11 AM | #7 |
good job, better to do it now than later.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
03-03-2017, 10:18 AM | #8 |
Got my C-notchs moved back 2" and a little more welding and grinding
I should have them back were they belong, also filled in the recess area were the stock steering column went. Allen |
03-03-2017, 03:33 PM | #9 |
Looks good.
Kim |
03-04-2017, 05:08 AM | #10 |
It's always a good idea to correct it now.
The wheel looks centered in the fender. May the Forum be with you. . |
03-06-2017, 08:17 AM | #11 |
Glad to hear 58/59's are longer as my 57 seems good at about 5/8 forward of the 27 1/2 from front.
How to tell when your getting old--- Aunt B starts looking good! |
07-01-2018, 09:00 PM | #12 |
58CameoAZ or anyone else with FO front on 58/59... couple questions:
What was the final distance you settled on from center of the wheel to frame front? How did you work with the boxing plates fitting weird in relation to the c notch and crossmember... did you trim it and scoot it forward or is it supposed to primarily box behind the crossmember? Thanks!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
