Old 02-18-2017, 02:03 AM   #1
Isaiah92260
Isaiah92260's Avatar
Defrost/Heater Shortening out
It's raining in so-Cal.
Was driving with the Deforster on, out of no where it stops working. Checked the fuse and the 10amp fuse is blown out. Pop a new one in, blows out again. WTF!!
Anyways does anyone know what could be shortening out my heater/Deforst Air? I have the very basic heater, I think it's a reticulating heater
Isaiah92260 is offline   Reply With Quote
Old 02-18-2017, 05:53 AM   #2
CRUZN66
CRUZN66's Avatar
Re: Defrost/Heater Shortening out
Mine was doing the same thing, ended up replacing the blower motor.
CRUZN66 is offline   Reply With Quote
Old 02-18-2017, 03:13 PM   #3
LP_Punk
LP_Punk's Avatar
Mine did this as well, I think because the heater core leaked coolant onto the blower motor. See if you have a leaking core, replace if needed, and buy a new blower motor.
LP_Punk is offline   Reply With Quote
Old 02-18-2017, 07:32 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Could be the wire to. If there's a crack in the insulation somewhere it could be rubbing against bare metal and shorting out.
Old 02-21-2017, 01:40 AM   #5
murdoc
murdoc's Avatar
TJ could be onto something there, definitely dont rule that out. I replaced my blower motor convinced it would solve the issue with the fuse blowing. I still have the same issue after replacing the blower motor.
There can always be an issue with the other electrical components, i.e. the fan switch, or even the fan speed resistor. If i get mine figured out I will be sure to update you guys.
murdoc is offline   Reply With Quote
Old 02-21-2017, 12:55 PM   #6
Isaiah92260
Awesome defienetly let me know if you figure out yours!
Old 02-21-2017, 02:16 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Same thing happened to me once in my GMC. Wire fell onto the big v6's exhaust manifold and it melted. lol Blew the fuse and luckily didn't hurt anything else. New piece of wire and a fuse and all has been fine. Almost mentioned this forgetting you have an I6.....no manifolds on that side.
Old 02-21-2017, 12:54 PM   #8
Isaiah92260
Thanks I'll check it out today since it's my day off
