02-18-2017, 03:53 PM | #1 |
Name that tool please, passenger head temp sensor plug
Hi
My 1969 Chevy 350 engine was rebuilt with newer heads. Head casting number 10147898 from 1995 crate engine. I am looking to add a temperature sensor on the passenger side, so I need to remove this plug. Can you tell me what tool to get? Some sort of a square drive tool. I tried inserting a socket wrench 1/4 drive and it is too little, 3/8 is too big. Is this something metric? |
02-18-2017, 03:56 PM | #2 |
Re: Name that tool please, passenger head temp sensor plug
3/8'' ratchet extension hooked to a 1/2'' breaker bar. Sometimes a little bit of heat with it
02-18-2017, 04:22 PM | #3 |
Snap-On P/N PPM410A 5/16" square drive socket or
PPM4110A 11/32" but a 3/8" fits the only old head I have around. |
02-18-2017, 04:45 PM | #4 |
Thanks! I see on Snap-on's web site they are calling them pipe plug sockets. Now that I know what they are called I see sets of them are available in male and female, or internal and external as Snap-on calls them.
Of course I have an oddball size so I can't cheat with with a common ratchet extension. :-) |
02-18-2017, 04:47 PM | #5 |
Yeah, that's why I bought the set, don't use em much but when you need em you need em!
02-18-2017, 05:20 PM | #6 |
Or a cheap extension from Harbor Freight and a couple of minutes on the grinder...
Just be careful not to get the work piece to hot, or it will soften the temper. |
02-18-2017, 08:03 PM | #7 |
That's what I did. Cheaper than buying a set of square drive plugs that I'll never need and faster since I had a spare on hand!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-18-2017, 08:44 PM | #8 |
x2, you may have to heat around the circumference to get it to break loose though. some of that aged pipe dope doesn't break loose too easily...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Tags |
plug, square drive, temperature sensor, tool |
