anyone upgrade their headlight on a 91 blazer k5?
have not found anything myself yet
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King |
Re: anyone upgrade their headlight on a 91 blazer k5?
Yes, I put a set of Hella H4 E code headlights in mine. I also added relays to the wiring. Huge difference in light output but not cheap. The stock headlights are absolutely pathetic.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
wow that is good news really was hoping for a set of LEDs but that sounds better than what i got for sure
thanks man
#4 | |
Another option would be making your own projectors but that would require a lot of fabrication. These housings are not very common and were only used on a few models. The Camaro's and Firebird's used this size housing as well as the Jeep Cherokee Limited's and that's about all that comes to my mind.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 02-19-2017 at 10:11 AM. |
I will look into the Hella. Since my truck is hella cool. Lol
Posted via Mobile Device |
4wheelparts $165 for 2 pair no relay included? did the relay come from?
Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 Rampage | Part Number: RPP5089927 This part fits your vehicle: 1991 CHEVROLET BLAZER BASE V8 - 5.7 Liter - GAS Change Vehicle Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com Click to Enlarge 3.8 Read 4 Reviews Qualifies for Free Shipping Technical Details Rectangular headlights Headlights are a direct replacement 60% more luminescence and D.O.T. approved Kit includes a pair of durable die-cast aluminum housings with s Questions(1) Answers(1) Overview Instructions Product Specs Update your dim stock headlight bulbs to a set of Rampage H4 Conversion Headlights that are a direct replacement, 60% more luminescence and D.O.T. approved. This is a simple 10 minute installation that requires only a screwdriver and the results will be incredible. Kit includes a pair of durable die-cast aluminum housings with solid clear glass lens and 2-H4 55/60W Bulbs. Imagine a whole new brighter nighttime driving experience that’s safer and less fatiguing.
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King Last edited by schpeen; 02-19-2017 at 01:37 PM. |
