Old 02-19-2017, 06:12 PM   #1
68Gold/white
Ever use one of those cast aluminum oil pans?
I am working on a 1970 350 for a friend. He bought one of those fancy cast aluminum oil pans. Mr. Gasket and others have made them for years. This one is not the polished one I've seen in the past on engines, it's flat black with fins, lengthwise, just like the polished ones.
My biggest concern is performance, this vehicle won't get any wild driving, but there's no baffle in it, just has a dam or vertical wall forward of the sump about 1 inch tall with a couple of openings in it so oil can drain back into the sump.
Thanks in advance!
68Gold/white is offline   Reply With Quote
Old 02-19-2017, 06:41 PM   #2
James the III
Re: Ever use one of those cast aluminum oil pans?
Just run it.. the alum fins will cool the oil. that was the point..
not for oil control.. add a windage tray hanging off the main studs/bolts.. and call it good..
James the III is offline   Reply With Quote
Old 02-22-2017, 12:11 AM   #3
Z10
Z10's Avatar
Yep. Installed it on a new ZZ4 over 11,000miles ago.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
