Opinions on this '71
This truck is pretty rough and has the usual problems in the usual places, but I'm eager to get your opinions on any obvious challenges with rebuilding it. My intent would be to do a thorough frame-off rebuild. The biggest challenge looks like it would be replacing the rotted sheet metal. It's going to need a new roof, cab corners, rocker panels, bed floor, lower doors, and probably more. The engine may be the strongest element but it hasn't run in a few years.
I will post a second batch of pics in a second post. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: Opinions on this '71
my honest opinion---that is about a 3 or 4 hundred dollar parts truck in Houston.
#3 | |
![]() Join Date: Oct 2009
Just so I'm clear - do you already own this truck or are you considering it? |
#4 | |
I do have some experience doing sheet metal body repair although I am not an expert by any means. My intent with this truck would be to build a reliable daily driver that also looked good. My latest total is about $13K in parts and work not counting the price of the truck itself, and that's IF the engine and tranny are good, however it's the unknowns that'll get ya, right? |
Ok, after seeing the second round of pics, I'm going to change my recommendation to "run faster".
Glad you asked. I'm no expert, but I've looked at enough of these trucks to know when to fold em, as they say. This truck is not a good buy at any price. Parts rig maybe - but NOT if you don't have the truck you're going to buy yet - the truck you eventually buy may not need any of these parts, and you'd be paying someone $50 to tow it away eventually. Regardless, whatever you spend on it is that much less you can spend on the next one that may have all its parts anyway. My 2c. I'd punt. |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Keepin an eye out
Couldnt give me that one...but I'd take the steering wheel lock/
![]() Keep looking.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#9 | ||
"I ain't nobody, dork."
I'd pass on that rig. That is a basket case.
Gary
![]() Join Date: Dec 2011
if you are considering doing a frame up rebuild as your first post states and are prepared for the challenge and are not in a hurry to get on the road and want to do a short bed here is another view of the truck..if it is a real short bed,frame is good other than surface rust,suspension is intact and useable,vin plate is intact matching title..it is worth a few hundred$ just for parts.Maybe truck could be bought without motor..next keep your eye out for a long bed with a decent cab and possibly a complete good running truck for a reasonable price and start swapping over...seems like the body of the truck in pictures is pretty far gone but the rolling frame would be a start if you had intentions of going all out.
#11 | |
My worry is that even if I could buy this truck very low cost, the money isn't really the issue: the time to repair of the sheet metal is the big part of this project. ![]() ![]() ![]() ![]() ![]() |
I'd pass on this one. Only advice I can give is to look for the the the most complete and rest free truck you can find. It will be cheaper and take less time in the long run.
What scares me the most about that truck is that every part on it has been "touched' by someone in the past. Many times that equates to more work than it's worth.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Born Psycho
![]() Join Date: Feb 2001
i agree 100%
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#15 |
Does it have a cross-ram Chevrolet HemiWedge from the factory? Otherwise I'd run away.
In all seriousness, if this were a big-block short-box AC truck with speed warning and Margot Robbie was the current owner, I'd go look at it. But it's not. There are WAY better trucks to start with. Find yourself one! Especially if you're going to do a frame-off rebuild, that's a 3-4 year fulltime project, you might as well spend it with something complete and unmolested. Now if you're doing a complete custom and don't need the stock parts and you're going to tub it and do a bunch of custom metal work anyway, then maybe. That's a lot of rust and nonsense for one man to deal with. This, however, is my favorite part. I think the truck is effectively keeping this valuable lock from being stolen!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#16 |
#17 |
I'll pile on. Definitely look for a better starter/build truck ( less rust ). This one is probably too far gone. Looks to me like there will be rust under the dash and in the cowl area too. You don't want that.
If you could get it for less than a grand, the motor runs, the tranny is good and it will roll under it's own power, then picking it up as a driver only might not be a bad plan. You'd probably spend another grant on it just making it safe for the road. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#18 |
![]() Join Date: Jul 2016
That's not even a god parts truck, buy something better, at least something mostly original without all the primer, bondo, holes and wrong parts everywhere you look. Honestly each and every picture has multiple problems shown.
#19 |
![]() Join Date: Sep 2008
well I will throw the only positive thing in the post. if its a real short bed and not a cut down the rolling frame which looks damn decent has to be worth what 500-750? and that motor even if good or not isn't original.
#20 |
That is ruff for a texas truck..BUT..
If you can get it for a song.. I'd get it running and that is it,,, drive it.. buy a better truck with less rust.. and rebuild that.. when it is done.. you can either park this one or sell it.. As a frame off build will take a few years , and one can slowly get better parts for this one as you drive it and go hunting for parts for your full build.. if this is more than few c-notes I'd walk.. bonus it can be a parts hauler while you building the good one.. it's always good to have a truck you don't care about when you are junkyard crawling or swap meat buying.. |
#21 |
Ok, I modify my answer, I see from the pictures that it appears to be a real short bed and looks like original 6cyl truck from the engine mounts. Could be worth saving if you bought a clean donor truck for the body change then you would have the problem of the cab VIN not matching the frame, you could fix that I guess.
#22 |
if you really want a short bed there are options. you can still buy a decent longbed in Texas pretty cheap. there is a guy here in Houston that can make it a shortbed. he can even cut the bed and they come out real good. shortbeds are getting pricey around here and harder to find. honestly I have given away better trucks than this one.
#23 |
Florida Edition
![]() ![]() Join Date: Oct 2010
It looks like a decent frame, that all it is. $500.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#24 |
I'm going to go out and kiss my truck right now!
#25 |
![]() Join Date: Sep 2005
Me too (my truck, not yours)!!! They are labors of love, for sure, and each one comes w/its own set of challenges, especially when "restoring" in whatever fashion one wishes to do so. That said, they are not for the faint of heart because to "restore" one properly takes a lot of time, a lot of patience, a lot of equipment and a lot of $$. Craigslist is littered w/failed attempts to "restore" old trucks.
