02-24-2017, 07:12 PM | #1 |
Glove box option codes
I'm having trouble reading the codes in the glove box. The picture is pretty rough. I'm pretty sure it says positrac 3.73, front door arm rest, hd clutch. The other says dark green I think. But dark green what? It is 1968 c10 stepside. Is currently hugger orange with a 350 engine and a turbo 350.
Posted via Mobile Device |
02-24-2017, 10:45 PM | #2 |
Re: Glove box option codes
It's RPO 505 - Dark Green Paint - solid color on the body. I believe you're correct on the rest.
Also, the Model # shows it as a 115" wb shortbed. Can kinda make out the 115 on the top right of the SPID - but it's a stepper C10, so that makes sense. Model # and VIN 2nd digit is a little sketchy. If it's an S, it was originally a 6 cyl. If it's an E, it was originally a V8 (307 or 327 in 68). Check your metal VIN tag to confirm. With the sbc or 6, 3.73 was standard, but posi wasn't, so that is why it's called out on the SPID. I believe the original trans would have been a 3 on the tree as the 4-speed would have been called out on the SPID if so optioned. And welcome to the site from another Hoosier (originally, I mean)! Last edited by jocko; 02-24-2017 at 10:51 PM. |
02-24-2017, 11:20 PM | #3 | |
