Old 02-27-2017, 10:53 PM   #1
Shtudwn
Alternator Voltages
Hi,
I have just replaced my battery and now I am suspect of my alternator.
I have 14.3V at idle with nothing on but as soon as I put a load on the system such as heater, lights, wipers, and turn signal....wow! I'm at 12 volts. is that common? Can't drive much at night in the rain!
Is the alternator week?
Thank you.
Shtudwn is offline   Reply With Quote
Old 02-27-2017, 11:05 PM   #2
slorio
slorio's Avatar
Re: Alternator Voltages
Shtudwn:
What is the voltage at the battery when you rev the engine off of idle with the lights, heater, etc. on? System should be able to produce 13.5 volts under such a load, but not unless engine is up above idle to an operating speed. Are you using a volt meter to read the voltage or are you depending on a factory gauge in the panel. Factory gauges aren't very accurate.
Hope that helps.
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 02-28-2017, 12:43 AM   #3
Shtudwn
Thank you Steve!
I reved the engine while checking the voltage. With everything on i'm getting above 14V. Yes!
Old 02-28-2017, 11:13 AM   #4
Wrenchbender Ret
Those readings are normal. Your alt is working good. Some of those early alt. did not have a high amps output. It may be a 42 amp. You can use a 55 amp. with external regulator or even higher with an internal regulator.
Wrenchbender Ret is offline   Reply With Quote
Old 02-28-2017, 11:23 AM   #5
slepysal
slepysal's Avatar
I recommend you install the headlight relays, they will take a load off the charging system
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-28-2017, 06:32 PM   #6
Wrenchbender Ret
Headlight relays are a good idea but the lights will still have as much load on the bat. & charging system. The lights will brighter & it will take the load off the light switches.
