![]() Join Date: Jun 2012
700r4 gear indicator question
Anyone found one for auto non tilt truck? I camt seem to find one. There was a guy on here that was going to make me one...but i deleted his p.m. accidentally and cannot remember his screen name.
Tom
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
![]() Join Date: Apr 2015
Re: 700r4 gear indicator question
I've looked and looked for one with no luck. I don't understand why they aren't more readily available. Does everyone really have a tilt column?
Moderator
![]() Join Date: May 2007
I don't know about everyone, but the first thing I do to a vehicle is swap in a tilt column if it doesn't have one already.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#4 | |
Im betting a piece of acrylic or plexigass could be made into an indicator fairly easily
How did I get this OLD!
![]() Join Date: Dec 2014
I've been looking too. Hoped to find one before the 2004r goes in.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
![]() Join Date: Sep 2014
Is this helpful?
http://www.lategreatchevy.com/full-s...1958-1972.html I was researching some time ago and saw this because I am updating to a 700R in my 72'. ![]() |
At the body shop.
http://www.gmcpauls.com/pictures/70-...enswtiltod.jpg
Just bought this, old blue has a van tilt. Pics when installed.
" That didnt make it any newer " " Dont antique the equipment " |
I think that's a unicorn part. As far as I can tell there is nothing made that will fit a stock non-tilt column. Places like Ididit and Flaming River make them for their own products, but the diameter is different.
I finally gave up looking and spent some time adjusting my linkage (and slightly modding the steering column) so that it will at least fairly accurately line up in Park, Reverse, Neutral and Drive. I can still use 1st gear but the pointer runs past the end of the indicator. No biggie, I don't manually select gears as a rule anyway.
Dennis '70 CST/10 '55 Bel Air wagon |
I found one once and bought it for my '72 that I had. I have no idea where I got it from, but they do exist.
Im hoping the guy that i had messaged a few times will see this and get back to me
Im going to make an overdrive lens for mine. I cant find one so ill just make one
Is it possible that the non-tilt indicator area simply isn't big enough for a 4-speed indicator, and that's reason no one has made one?
It depends whether the four-speed "packs more gears into the range" or "extends the range by one gear". It might be a little of both, and it runs out of room. Anyone have a four-speed trans and a 3-speed indicator to speak to where first winds up landing on the indicator?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
I have one on my to do list, and I thought the ones listed in LMC would fit. I will keep watching to see if anyone finds a source, or I may try to mark one on a piece of lexan or polycarbonate?
#14 | |
#15 | |
Moderator
#16 |
You may be right. It could be that it is to big for the actual lens. I intend to make one and instead of "park", itll be P R N O D 2 1 to give me a little more space on there. Maybe that will work
#17 |
What if you sand and polish an original and apply a decal on it, I'm sure a sign shop could make one with clear film?
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#18 |
I just did some grinding to my column and now it will fetch the 1st gear. It does however move past the original first gear and somewhat past the housing if i remember. I will try to take a pic. No bigge for me as I only look down to see if I am in reverse or park.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#19 |
Yea post up a pic
#20 |
Thanks for confirming! That's what I figured...
#21 |
Guess i could leave it alone and know the pointer wont line up. How much do i need to manually shift to first gear anyway?
#22 |
I changed my steering column to a Van unit, I can send you my old one if you like..... just pay for the postage..... pm me with your address and I'll send it out
Monday. Ben Smith ![]() One thing I've noticed with my Van tilt column, is the internal detent plate makes it difficult to shift all the way to first (700R4 has a low first gear and add that to my 3:73 years makes for a very quick up shift) I used threaded rod ends, r/h and l/h threads to make a turnbuckle shift rod so I could adjust the indicator.
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” Last edited by snipescastle2; 03-03-2017 at 11:41 PM. |
#23 | |
#24 |
Here's my standard column od indicator....
I used the "Ididit" column indicator that comes with adhesive on it but I used a different approach to attach it to the column I took the stock indicator lens and traced the shape of it onto a piece of scrap Lexan, then cut it out with a scroll saw. I took the Lexan and attached it to the indicator housing, I then took a small dab of clear RTV and affixed it to the Lexan. Looks pretty good, but not perfect. I think the indicator from Ididit cost about $30. Since there aren't any alternative pieces This fit the bill. Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
#25 |
That looks good, i can dig it
