Old 03-07-2017, 07:20 AM   #1
loujizzel
Ned help cargo lamo wire
hi guys, ok prior to me doing a cargo lamp delete both cargo light and dome light were working off the switch. but since the delete the cargo lamp delete the dome light will not come back on, i have the orange and white wire snipped off at the ends.. and the dome light is still wired up.. how can i wire it up so that the switch work for the dome light only....
loujizzel is offline   Reply With Quote
Old 03-07-2017, 12:09 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Ned help cargo lamo wire
Have you checked to make sure you have power in and out of your switch and the bulb? Im trying to remember but I think mine only worked if the lights were on.(maybe that was just the cargo light).I know I rewired my lights with a constant power supply so theyd work when I wanted them to
Old 03-07-2017, 01:31 PM   #3
loujizzel
Thanks for the reply but it was working even if the truck was off I read somewhere that it's part of the circuit the cargo light I mean so the cargo light works with the dome light it actually completes the circuit so just trying to figure out how I can delete those wires and still make the circuit I am definitely not an electrician
Old 03-08-2017, 07:53 PM   #4
loujizzel
So after reading and looking at diagrams it seems like the cargo lamp is the switch. Now that it is gone my cab light wont work because the circut is not complete... i took some pics so you can see my situation and maybe someone can give me and ez fix ( it's never easy)
Pic 1 where the cargo lamp used to be
Pic 2 the dome light
Pic 3 the remaining wires after cargo lamp was deleted
Pic 4 the backside of the switch the back side of the switch
Old 03-08-2017, 07:58 PM   #5
loujizzel
Pics 3 and 4
Old 03-08-2017, 08:47 PM   #6
mongocanfly
One of those wires coming up behind the door post is going to be your interior light wire..it will only have power on it when the door is open or you have you headlight switch turned for interior lights..find that wire and hook it to the hot wire going directly to the interior light..bypass the cargo light switch..you won't need it..like I said I wired mine independent of each other..
Old 03-10-2017, 04:35 PM   #7
mongocanfly
Sorry I steered you wrong at first..for some reason I was thinking the switch sent power to the light..not that the switch actually completed the ground circuit
Old 03-10-2017, 04:48 PM   #8
loujizzel
Talking Re: Ned help cargo lamo wire
No worry brother I think what I'm going to do is take the orange wire that I have cut from the cargo light and I'm going to run that to a hot lead maybe even the battery of the car and then I'm going to ground the white wire and see what happens what else can I do but blew a fuse
Old 03-12-2017, 03:15 PM   #9
Pontiac1976
Pontiac1976's Avatar
I know I late but the cargo light wiring just unplugs. Up near the dome light you did not have to cut wires.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-18-2017, 02:30 PM   #10
loujizzel
for all those who gave me some ideas to ix my little problem thank you... its working the way i want it to
Old 03-18-2017, 03:39 PM   #11
mongocanfly
Good deal...
