Old 03-17-2017, 11:42 AM   #1
Enginewolf
65' truck future 472 caddy swap
Hello forum I'm new here, recently I've purchased a 1965 gmc 2500 fleetside, I've got a 1968 caddy 472 big block that I plan to swap into the truck and just wanted to see if anyone else has done this swap before (I know they have, by no means is this swap new) and was just trying to get some advice, pointers and helpful knowledge to steer me in the right path to completing this swap. Thanks everyone for any info given in advance
Enginewolf is offline   Reply With Quote
Old 03-17-2017, 11:56 AM   #2
KenAdams
KenAdams's Avatar
Re: 65' truck future 472 caddy swap
There is a couple 500/472 Swaps around here, one I found:
Local 29's http://67-72chevytrucks.com/vboard/s...d.php?t=685367
KenAdams is offline   Reply With Quote
Old 03-17-2017, 12:03 PM   #3
Enginewolf
I saw that posting too, sadly that truck already came with the engine when he bought it so it didn't really help me with the process of doing the swap
Old 03-17-2017, 01:44 PM   #4
63 & 64 Bowties
and a few others
Board member Longhorn Man did one probably 10 years ago. I don't think he ever did a build thread on it though. And, he's not active on here anymore.
His was a 67-72 but it will all be the same.
If you search for his past posts, he always refers people to this thread:
http://67-72chevytrucks.com/vboard/s...ad.php?t=20020
This truck was also already completed when the thread was started. I haven't read through the whole thread but I guess there's lots of useful info towards the end.
Good luck. Nice to see someone who's not doing the standard SBC swap.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 03-17-2017, 01:49 PM   #5
Enginewolf
I saw he was the man to talk to and was sad to see he was no longer on here. The truck has a 350 in it now but it's going out! I'll go through his thread and see what all I can get from this. Thanks for the link
Old 03-18-2017, 12:02 AM   #6
64shortbox
64shortbox's Avatar
Enginewolf,
I was going to this swap myself but the freshly rebuilt 472 I was supposed to get got sold before I could pick it up.
But here's what I remember IF I remember correctly. You need an oil pan out of a 472 to 500 CI inch Eldorado. The regular Caddys are front sump pans and won't work with our trucks.The Eldo pans look funky because they had to clear the drive axles. Another option I read uses the 368 oil pan. It will work with a 472 Caddy Motor but not a 500 unless you clearance the side of the pan with a BFH to clear the stroke of the 500 crank. The 368 is considered a mid sump pan but will supposedly clear in our trucks. You will also need the correct long oil pick up tube & screen to match the pan. You will also need the front oil pump off a 425 or 368 because the oil filter is moved to a different angle to clear our frames and they take a smaller oil filter. Of course you will need the 425, 472 or 500 motor mounts - the frame & motor sections. Any other questions or concerns please ask. It's been a while but I dug into this a few years ago.
64shortbox is offline   Reply With Quote
Old 03-17-2017, 09:37 PM   #7
jdl71
jdl71's Avatar
One of my friends in high school drove one of these trucks with a 472 in it. I don't know much about the swap as I was only 16 or 17 and it was 30 years ago but I always thought it was way cool. BTW the truck you have pictured has a chevy grill and hood, not trying to nitpick but there is a difference between GMC and Chevrolet in these years. Are you certain you have a GMC?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 03-17-2017, 09:58 PM   #8
Enginewolf
Yes it's a gmc with a Chevy grille that guy I bought it from couldn't find a gmc grille for it so he settled for the Chevy grille
Old 03-17-2017, 10:01 PM   #9
jdl71
jdl71's Avatar
Looks like it's in pretty good shape. Welcome to the forum, and good luck with your project.
Psalm 23
64 C10
66 K20
Old 03-23-2017, 11:36 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I bought a 64 gmc with a caddy motor in it. they cut a big notch in the cross member to clear the oil pan, and they also trimmed the firewall a bit to clear the valve covers.
Old 03-24-2017, 03:38 PM   #11
oldusafmsgt
oldusafmsgt's Avatar
This was a very popular swap back in the day (I'm old), did a few of these . We took a BFH to the firewall, notched and boxed the front crossmember to clear the oil pan. Mounts were fabbed from a donor Caddy, not all that difficult. These torque monsters were perfect for towing our race cars. If you could keep gas in it.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
