![]() Join Date: Mar 2016
Rear trailing arm torque
I just replaced the trailing arm bushings on my 62 and I was wondering how much to apply when I put the bolts back in. any help would be appreciated.
Re: Rear trailing arm torque
Bolt tourque chart suggest 80 ft lbs for grade 8, 1/2"
115 for 9/16"
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Thanks for the information.
Never Ending Projects
From the GM manual, those are 140 ft. lbs and you want them at ride height when you torque them, not hanging down.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
I did 140 as well
