Need help troubleshooting fresh swap
Hello everyone , I have been lurking here for a while but this is one of my first posts. I recently swapped a 2005 LQ9 6.0 into my 69 GMC and I recently got it running but it's having issues. I purchased hp tuners pro and I have eliminated the vats and the rear o2 sensors. The engine runs fine when fire started but it will slowly start running worse. If I try to drive it it acts like it's in low power mode but I am not getting a dtc indicating it is. The only thing that strikes me as odd is I do not see any response from the o2 sensors. One came with the swap and the other is new but neither seem to be reading any voltage on the hptuner software. However if I disconnect one of the sensors I get a code for a o2 sensor unplugged. My thought is I should be seeing something from the o2 and since I am not it leads me to believe this is the cause of it running bad. I haven't been able to add a wideband o2 to the system yet to check the a/f ratio. I am still learning all of this software and this is my first ls swap. Any advice would be appreciated.
1969 Longbed 6.0/4l60e |
meowMEOWmeowMEOW
Re: Need help troubleshooting fresh swap
unplug the maf, does it run better.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I unplugged the maf and is does run better than it was but could still be better. I have been reading more and it sounds like I need to do some adjustments to the maf tables.
#4 | |
meowMEOWmeowMEOW
![]() Modded MAF tables, VE, PE or any of that stuff will make some of this impossible to diagnose, as we can't bear witness to any of what occurred. If you don't have a stock flash availalbe, check the HPT repository.
#5 | |
I had a problem with my swap were the engine seemed to be in limp mode yet no codes were being thrown. Ended up being that the O2 sensor plugs were switched and the left plug was in the right sensor and the right plug was in the left sensor. I switched them and it ran fine after.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 ![]() |
#7 | |
#8 | |
![]() Im happy to be of assistance!! ![]()
Thanks for the information and good luck..
#10 | |
I also will be getting a replacement power cable for my AEM wideband gauge today so that should help figure out what exactly is causing the issues. I appreciate the input everyone!
meowMEOWmeowMEOW
another solve for the forum. We gotta have a pretty high clearance rate
