Has anyone used this tank? Boyd's Aluminum Fuel Tank
Hey y'all, was curious if anyone has used this tank on their builds? I like that the pump is in the tank so the pump will stay cool. They say it'll fit but you never know.
http://www.fueltankparts.com/67-72-e...-bed-fill.html Lemme know what y'all think. |
![]() Join Date: Aug 2004
Re: Has anyone used this tank? Boyd's Aluminum Fuel Tank
I have one, fits nicely in my 65
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Jan 2011
I have one with out the pump in the tank in my 66 and it is a nice fit and a pretty simple install. It needs the spare tire brace removed but that has to go for all the rear tanks. I have a second one sitting here on the floor that will go in soon. It has the in tank pump and like everything else Boyd welding does its a nice piece. Got the rest of the fittings in today for the efi install.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Ditto what Jimmy said.
I also have the external pump and it's not loud at all( Pierburg)
I have that tank. I haven't run it yet, but it's been installed for a few years now. Had to remove one small crossmember which was no biggie. I welded nuts to my frame that the tank bolts to, so it's easy to drop the tank once the bed is on. Seems like a very high quality unit.
I have this tank in my '66. Pump in tank, pretty simple effort to install it. I've got about 600 miles since I put it in and I'm quite happy with it. I've never spent a millisecond regretting the decision to buy one.
I just got there tank it's the side fill and the filler neck won't clear the wood bed floor it's over a 1/2 inch to tall it's in a 1969 c10
60-66 Nut
Have you contacted Boyds Welding about this issue?
