10-18-2003, 05:12 PM | #1 |
WHYBYNU when old will do?
Look at what I found at the yard today!
Went to a local salvage yard today (out at college), and grabbed this off an 87 3/4 ton 2wd GMC. Only paid $20 for it! It even has all 4 brackets in good shape too. Now I just have to find out the diameter so I can get new bushings for it. Anybody have a guess?
-72 Chevy C10 Stepside -2002 Chevy Silverado 2500HD 4x4 -1984 Jeep CJ7 -1995 Polaris XCR600 Custom -2003 Honda 300ex |
10-18-2003, 05:21 PM | #2 |
Formerly yellow72custom
Sweet deal!
Just measure the cross section of the bar with a ruler....it is proably 1-1/8" if it is off a 3/4 ton.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
10-18-2003, 06:02 PM | #3 |
Watch out for your cornhole !
Adjust a crescent wrench to fit it real snug, then remove the wrench and measure it with a ruler.
I'm betting it's a 1 1/4. If so see my FAQ swaybar page for bushing part number.
10-18-2003, 09:23 PM | #4 |
Thanks guys!
10-18-2003, 09:29 PM | #5 |
I am a Referee of life.
You can use a fitted wrench to find size.If a 1 1/4 fits over it but a 1 1/8 doesn't figure it's a 1 1/4.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-18-2003, 09:48 PM | #6 |
sweet. wish i had one of thsoe
70 longbed 496/th400/Ford 9" |
10-19-2003, 06:06 PM | #7 |
Not Dusti,just Bob
72c10step,
Did you get the 2 brackets off the frame?They are riveted on and a pain to get off when you are out in a wrecking yard. Bob W
72 cheyenne super 1/2ton 89 camaro |
10-19-2003, 06:52 PM | #8 |
KEEP ON TRUCKING
cool
72 cheyenne 2wd lwb 71 k20 sons bassett va |
10-19-2003, 08:27 PM | #9 | |
10-19-2003, 08:32 PM | #10 |
Frame brackets are GM part number 6271375
10-19-2003, 08:41 PM | #11 |
They are both the same part #? Thanks for the info TX Firefighter, I've been following your thread in the FAQ section of your install. Very well done!
10-22-2003, 03:36 PM | #12 |
Finally got a chance to measure the sway bar today with my friend's tools. I used TX Firefighter's method of putting the crescent wrench around the bar and measuring the opening. The wrench only went 1 1/8" wide, and didn't fit over the bar, so it must be a 1 1/4" bar. Thanks everyone for the ideas! Check out my new post (part 2) to see the stuff I found today!
