04-01-2017, 11:15 AM | #1 |
Body mount
I'm planning to replace my body mounts. How do I separate the body from the frame? Can I raise the body to get the gaps I need to remove the old bushings?
Will it hold? Need good advice Thanks |
04-01-2017, 11:54 AM | #2 |
Re: Body mount
I just use a floor jack and a block of wood. Don't have to lift it much, just support it enough to slip the mount in
04-01-2017, 12:49 PM | #3 |
Re: Body mount
04-03-2017, 12:25 AM | #4 |
Re: Body mount
If I remember right the very rear one I placed the jack in the corner and the center mount was under the A pillar. You could probably lift the whole side with the block of wood under the floor brace. Don't have to pick it up much
04-03-2017, 01:35 AM | #5 | |
Re: Body mount
Thank you for sharing. |
